RT360 re-sleeve/boring
  • Enduro nut
RT360 re-sleeve/boring was created by Enduro nut
Hey guys i have 2 1973 RT3 360 cylinders that need work. The first one is currently bore 60 over (1.5mm) and it needs to go to 80 (1.75mm) but cant seem to locate a piston that size for it. The 2nd cylinder has a small crack down at the bottom and is standard bore. Does anyone know if these can be re-sleeved and if so where to get a sleeve?
04 Oct 2021 08:47 #1
Replied by RT325 on topic RT360 re-sleeve/boring
I run a 2X5 piston kit from a "one year only" "79 model YZ400F. 82mm. Need about 5mm of the skirt base to match the original piston except i forgot to do that on one of mine & is ok. Just gets close to the crank at bdc. Top of the cutaway is about the same as top of the windows on original. Head needs a slight tweak in the lathe to take the edge out a couple of mm to clear. Not sure how far past 82mm you'd get away with but i have an 82.25 so i'll find out one day maybe. Here's a link but only a piston. Should be complete kits out there. Good luck which ever way you decide but buying a good cylinder might be cheaper.
www.nospartsnow.com/nos-yamaha-1979-yz40...ton-2x5-11631-00-96/
04 Oct 2021 13:49 #2
  • Enduro nut
Replied by Enduro nut on topic RT360 re-sleeve/boring
Tempting however machining isnt exactly my strong suit. I wonder if i could use a standard DT400 piston which would be 85mm but that may be too far. Or better yet are there over size rings for 1.5mm over?
04 Oct 2021 20:05 #3
Replied by MarkT on topic RT360 re-sleeve/boring
Have you checked with the original Enduronut on a piston and/or rings?  He would be a likely source to have whatever piston/rings you need.
A member in the UK (if I remember correctly) had a nice resleeve done.  You might also check with...  drawing a blank on his member name...  Rich's Taylor'd Porting in Utah.  richstayloredporting.com/  Rich might be able to help or might know who can resleeve.
04 Oct 2021 20:23 #4
Replied by DT Tim on topic RT360 re-sleeve/boring
I can’t help with a machine shop but yes, they can be sleeved successfully, I have a few hundred miles on my 400 now with no issues.
Last edit: 04 Oct 2021 23:41 by DT Tim.
04 Oct 2021 23:41 #5
Fins just about fall off at 85mm. Tried it on an RT2MX cylinder with a YZ400D piston & was into the aluminium in places & still not quite there. Was kicking myself when the machine shop rang me with that news.
05 Oct 2021 01:46 #6
  • Enduro nut
All good advice i will reach out to rich for sure and go from there but its probably better to just find one that needs a hone job. I know it will be cheaper that way especially since i have a standard piston all ready to go.
05 Oct 2021 07:34 #7
