CT3- Shurley
- ksours
Replied by ksours on topic CT3- Shurley
OK I removed the cover case and the pressure plate is moving @ 2mm . If I adjust it a little tighter on the push rod ( 1/4 turn back off vs 1/2 turn back off ) Will this give me a little more? Do I need any more movement? The friction discs needed a little help but were loose when disengaged.
01 Oct 2021 17:50
#11
Replied by RT325 on topic CT3- Shurley
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=114968850207&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- ksours
great info. Thx
01 Oct 2021 19:36
#13
Replied by MarkT on topic CT3- Shurley
Yes, parts diagram is misleading. Two washers and a bearing go together, not one washer and a bearing as drawn. A thin washer is actually sold with the bearing.
01 Oct 2021 19:39
#14
- ksours
OK on an initial post I stated there was an extra washer. I found where it belongs now. If I put the washer back in I suppose the sequence would be washer-bearing-washer ?
02 Oct 2021 04:08
#15
Yes, as you describe. I must've missed reading that in initial post.
That is,--thin washer 'bearing size', then bearing, then thick washer shaft size to butt up to the spacer which runs against bearing..
- ksours
Sorry for the misunderstanding. It was in a previous post, when I first took off the clutch basket. Appreciate the help.
02 Oct 2021 07:28
#17
There are a couple of different arrangements of washers over the years so I get confused sometimes. I can always do it right if I'm looking at the parts so pictures help. I also don't remember seeing a comment on an "extra washer" as that's a red flag.
I think on yours it's the thinnest thick washer with the smaller inside hole that goes on first. The long sleeve bushing goes on next and sits on top of the washer. Starter gear and clutch basket go on next. Thin washer that has hole big enough to fit over the sleeve bushing is next. Then flat roller bearing. Then the thickest washer... ...I think it's the thickest and the OD is biggest... goes on next. This last washer sits on top of the sleeve, does not slide over it. Then inner hub. Then bend-tab lock washer and nut.
If you slide everything on all the way and then tighten the nut you're usually okay... if you pull up on the inner hub or aren't careful, the flat roller bearing can slip off the edge of sleeve bushing and get pinched. Bad and can destroy the bearing. So as you snug down the nut make sure the inner shaft/hub freely rotates (have trans in neutral). If it starts to bind up and you tighten nut, stop and check that bearing hasn't slipped down.
02 Oct 2021 07:48
#18
- ksours
Update on clutch: When I initially went into the clutch I had posted that I found an extra washer. I went back to my parts drawer and it was staring at me . Mark T replied that the parts diagram was wrong and that there was an extra washer. It fit just as he described. After installing it I had to go back and re-adjust the pushrod and the lever. The clutch still has @ 2mm of movement on the pressure plate when you lever it. I think I am good to go. The bike is on a stand with the rear tire free to move. I put it in gear and initially the tire acted like it didn't want to move freely with the clutch in. I moved the tire back and forth and it freed up. Let the lever out and it was in full gear. Are there any more tests before I put the covers back on and add oil?
02 Oct 2021 09:07
#19
Sounds good. Good work.
02 Oct 2021 09:22
#20
