Best way to attack this shock bolt
- hcdiiiga
Best way to attack this shock bolt was created by hcdiiiga
Shock bolt on the chain side. It's going to ruin the inner threads if I force it out. My only idea is to take a dremel and grind the bad threads away.
25 Sep 2021 09:00
Replied by Gr8uncleal on topic Best way to attack this shock bolt
Maybe try to find a die in the form of a nut and repair the thread before removing. Or, if you remove the bolt as is, it might be possible to use a tap to correct any damage to the thread in the swing arm.
On my RD350B, someone had forced on a crown nut to the upper fork mount with the wrong thread pitch, but I managed to correct it with a nut shaped die with the correct pitch.
25 Sep 2021 09:19
- msavitt
Replied by msavitt on topic Best way to attack this shock bolt
I would cut if off close to flush with your dremel
The following user(s) Liked this Post: MarkT, RT325, MACE6772, rodent, Ht1kid
25 Sep 2021 09:32
- turbodan
Replied by turbodan on topic Best way to attack this shock bolt
Either grind off the bad threads like you said or cut if off close like msavitt said. Don't know which would be quicker and easier.
The following user(s) Liked this Post: MarkT, MACE6772
25 Sep 2021 09:53
- alnarv
Replied by alnarv on topic Best way to attack this shock bolt
I have used a small "V" shaped file to clean up threads like that.
26 Sep 2021 06:59
- hcdiiiga
Replied by hcdiiiga on topic Best way to attack this shock bolt
i forgot I have a thread file around here if I can find it, bunged up the threads a v strom countshaft one time. If not, I'm going to spring for a Harbor Freight tap and die set, see if that works before I start cutting.
26 Sep 2021 18:08
- RT360Fan
Replied by RT360Fan on topic Best way to attack this shock bolt
Those threads might clean up fine with a proper file. Thread restorer die would obviously work too. Good luck!
26 Sep 2021 18:31
Replied by RT325 on topic Best way to attack this shock bolt
If you go with a tap n die set just be sure the 10mm is 1.25 pitch. Other thing is if its damaged is it because someone has belted it end on a compressed the threads so running die over makes what you can see look nice but might not be in time with whats in the arm--i'm complicating things sorry.
26 Sep 2021 21:53
