Why would someone do this?
- tlh0824
Why would someone do this? was created by tlh0824
it looks like someone drilled a little hole in the carburetor, any ideas why?
is this carburetor ruined?
11 Sep 2021 16:32
Replied by MarkT on topic Why would someone do this?
It's fine.
They probably had an aftermarket air filter that kept popping off so they screwed it to the carb.
11 Sep 2021 17:08
- asco
Replied by asco on topic Why would someone do this?
Rear flange no problem. Possibly to secure air filter? Put som clear silicone in it and forget about it.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
11 Sep 2021 17:10
Replied by RT325 on topic Why would someone do this?
Na, not ruined. They probably ran out of a clamp so decided to do that--not a good idea is it but hose wasn't going to fall off. Is there one opposite on other side too. If your hose is a good fit just clamp as original, she'll be good. Could bung the hole with some epoxy mix if ya worried but hose will cover it right where the clamp sits.
11 Sep 2021 17:11
- tlh0824
Replied by tlh0824 on topic Why would someone do this?
Great thanks!
11 Sep 2021 22:32
