DT175 Reed cage question
  • MotoDave0
  • MotoDave0's Avatar Topic Author
DT175 Reed cage question was created by MotoDave0
Just wondering if this looks correct?
74 MX250 in a Profab frame
70 AT1 in a Trackmaster frame
72 RT2MX
72 DT2MX
74 MX360
Future rebuilds:
73 AT3
74 YZ80
71 JT1L 60
06 Sep 2021 22:23 #1
Replied by shyted on topic DT175 Reed cage question
It does from my sofa in the UK MotoDave0. Looks the same as a TY 175,which fits straight in my CT3.
I'd even like to bet it fits that AT3 you have too.
Take it it's out of a twin shock DT ?
Ted
07 Sep 2021 05:59 #2
Replied by MarkT on topic DT175 Reed cage question
Could be the camera angle but are the reed stops bent unequally?  Some of the manuals have a spec for the reed stop gap at the tip
The following user(s) Liked this Post: Swoop56, shyted, Ht1kid
07 Sep 2021 06:26 #3
  • MotoDave0
Replied by MotoDave0 on topic DT175 Reed cage question
That is what my question was about was the reed stops.
They look to close, the reeds will not open hardly at all
I am going to install a set of Power Reeds do I need to keep the Reed stops?
72 RT2MX
72 DT2MX
74 MX360
Future rebuilds:
73 AT3
74 YZ80
71 JT1L 60
07 Sep 2021 16:36 #4
Replied by RT325 on topic DT175 Reed cage question
Looks closed up on the stops & uneven. Bend them out equally. I bend them until they scrape the housing on the way in thinking more is better which isn't necessarily true. Check the screws after tweaking the stops.
07 Sep 2021 16:42 #5
  • MotoDave0
Okay RT325. That sounds good. I am putting a 175 jug that has been worked on.
On a DT125 bottom end. try and make a racer out of it.
Thanks again.
72 RT2MX
72 DT2MX
74 MX360
Future rebuilds:
73 AT3
74 YZ80
71 JT1L 60
07 Sep 2021 17:27 #6
Hey, now i'm sitting up & taking notice haha.
07 Sep 2021 17:44 #7
Boyesen dual reeds will kill top end in my experience.  Can give a neat mid-range kick but suck for HP.  Yes, you do remove stops with Boyesen.
Manuals have the answers...  but I've also done what RT325 mentioned and tweaked the stops as far as I can...  which isn't much.
The following user(s) Liked this Post: MotoDave0, JayB
07 Sep 2021 19:03 #8
I remember dads YG1T & it stripped the center drive out of the fiber rotary valve--which we did a few of at work--& i just screwed a reed petal off something yamaha straight over the inlet hole & left the rotary disc off, probably just had the steel center bit in place as needed for spacing crank gear. It worked ok just gutless but for him it was usable until i got a disc.
07 Sep 2021 20:25 #9
  • MotoDave0
Thank you, MarkT.
Great info.
72 RT2MX
72 DT2MX
74 MX360
Future rebuilds:
73 AT3
74 YZ80
71 JT1L 60
08 Sep 2021 05:39 #10
