CT3 handle switch
- ksours
CT3 handle switch was created by ksours
Handle switch for my CT3 is in very bad shape. The connector bar for the power supply is falling apart. Ebay has 1 for $279 and this bike has some aftermarket parts so I don't want to spend that kind of money. Do you know of another switch that I can wire in myself to replace this one? The plug ins can be rewired and I am only concerned with the handle bar fit and the common wires. I have power to the switch but the switch internals need replaced.
233-83973-00-94
233-83973-00-94
31 Aug 2021 08:26
Replied by Gr8uncleal on topic CT3 handle switch
Could you post a photo of the damaged part(s)? Just so we all know which ones we are talking about!
31 Aug 2021 08:29
- ksours
Replied by ksours on topic CT3 handle switch
here you go Thx for the fast reply- Karl
31 Aug 2021 08:45
Thanks.
Might be my eyes, but I can't see anything broken.
That bar with the three wires (dark green, dark brown and brown/white) is for the indicator switch.
By the way, DEET here on the forum does nice replacement silver/grey wire sheathing.
31 Aug 2021 09:33
- ksours
sorry the indicator switch bar was in pieces and I super glued it .
31 Aug 2021 09:46
So is that the part that you are looking to replace? If yes, how wide is yours? I would imagine that your switch housing is stamped YHA205 on the underside, but it could be that the bar from the early YHA206 might fit.
I'm guessing you're in the US?
31 Aug 2021 10:24
- JayB
Replied by JayB on topic CT3 handle switch
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=183505450028&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- ksours
Did you wire this switch into a CT3? Mine only has 7 wires
31 Aug 2021 10:36
- ksours
Yes it is a YHA205. The bar is 13/16" ( i glued it so + or- 1/16 )I have power to the horn but button does not work or horn is shot ( new one on the way) and I can't seem to get anything going on the light. The switch was frozen up and I cleaned it but i'm afraid it may be a parts-part. I could replace the bar perhaps but the light will still need to be addressed. Is there a 7 wire replacement for this switch?
31 Aug 2021 10:42
- JayB
No, I did not wire it to a CT3. Unfortunately for me, I don't have one.
I, or others on the forum, would help you figure out the wiring. Depending how the new switch is wired you might end up with an extra headlight on/off switch. I think the USA CT3 had a 3 position key switch: off, on and on with lights.
31 Aug 2021 10:43
