dt2 right crank seal
- austinbikergirl
dt2 right crank seal was created by austinbikergirl
While tearing down the motor for rebuild I noticed something unusual about the crank seal. According to parts diagram it has been installed incorrectly. Has this seal been incorrectly installed or are the reference materials wrong?
11 Aug 2021 09:45
- tvrc18
Replied by tvrc18 on topic dt2 right crank seal
I think it is backwards, the numbers on the seal usually point outwards and that spring should be on the inside.
11 Aug 2021 09:58
- JayB
Replied by JayB on topic dt2 right crank seal
Like crankcase stuffing, it reduces the lower end volume to increase the primary compression ratio!
11 Aug 2021 10:47
Replied by MarkT on topic dt2 right crank seal
Reference materials are wrong.
That crank seal is installed correctly. If you had it removed, it should have "castle turret" nubs on the other side that go in first to prevent the seal from being pressed in too far and cutting off oil flow to crank bearing.
Yamaha 250/360/400 crank seals are the exception to the "numbers out" general rule.
The following user(s) Liked this Post: swm, JayB, KennyV
11 Aug 2021 14:11
Replied by RT325 on topic dt2 right crank seal
I think its an aftermarket single sided seal so they've decided on putting the spring towards the oil--which sounds like it worked in this case. I have a pair of those cheapy seals but so far not used them--but will oneday.
11 Aug 2021 15:32
- LETSJET
Replied by LETSJET on topic dt2 right crank seal
Great information! thank you.
12 Aug 2021 07:24
