Replacement bulbs, speed&tach
  • Sneezles61
  • Sneezles61's Avatar Topic Author
Replacement bulbs, speed&tach was created by Sneezles61
I went to look for bulbs for the as mentioned above, I see a LED replacement... Is that sacrilege or can they be embraced? The same LED story, uses less power, less heat and better light emitting qualities... Durable it sez..
I'm not able to cut and paste the company.. so heres their local. superbrightLED.com..
Sneezles61
28 Jul 2021 14:29 #1
Replied by Bigdog302 on topic Replacement bulbs, speed&tach
LED lights require D/C current and your instrument lights are on A/C current. I guess the easy way would be installing a Vape 12 Volt D/C mag kit to do this.
Dave
Jesus is Lord!
28 Jul 2021 15:06 #2
Replied by Pedalcrazy on topic Replacement bulbs, speed&tach
Embrace the vintage enduro....leave it 6 volt and buy the correct 3 Watt bulbs. I've always been able to find what I need on Ebay.
The following user(s) Liked this Post: Quartermaster35
28 Jul 2021 17:20 #3
  • Sneezles61
Replied by Sneezles61 on topic Replacement bulbs, speed&tach
Well, I wasn't fighting the "usual" scenario... Now I have more stuff too study up on...  volt AC...
Am I suppose to say thanks or Dag Gummit?
Sneezles61
28 Jul 2021 18:18 #4
  • Sneezles61
Well, I'm trying to get an understanding.. Why would Yamaha utilize AC for instruments and headlight and not put a bigger full wave rectifier in  and run all its lights on a DC.. They did only for the ignition and battery charging side..
Maybe using a rectifier wasn't as reliable way back then? It couldn't have added any perceivable weight to the bike...
Perhaps its just wrong.. but I'm going to experiment with this stuff before I put the tank back on and get my bike out the door for riding enjoyment.. I hope there is some electric guru out there can shed the light..
Sneezles61
29 Jul 2021 07:01 #5
Replied by KennyV on topic Replacement bulbs, speed&tach
Interesting! I remember putting LED bulbs in my stock 250A tach and speedo years ago. I just checked to make sure and yep, their still there. I bought them from Superbright. I have one in the high beam indicator, tach and speedo each have one for the back lighting. I do have one "standard" bulb in the turn signal indicator? The led work great no problems, I like them. I think I'll buy some more so I'll have one for the turn signal indicator.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
Last edit: 29 Jul 2021 09:57 by KennyV.
29 Jul 2021 09:56 #6
  • Quartermaster35
  • Quartermaster35's Avatar
Replied by Quartermaster35 on topic Replacement bulbs, speed&tach
In my experience, as long as the polarity is correct, you can use an LED bulb.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
29 Jul 2021 11:03 #7
  • Sneezles61
Lotsa reading this AM... I'm getting a little more understanding as to why...
And yes LED lights can work.. and they are to be wired with polarity in mind... I've read that even as little as 3 volts will make a LED (small ones) glow..
 The issue I'm trying to solve... my bike was ran without a working head light and lights are fried... I'm sorting out the wiring.. And the way the battery works in the system as a whole...
I believe I have a handle on repairing some stuff and what wires make it tick... correctly.. Now.. out to the garage for some adventure...
I've gotta make a make-shift temp gas tank to check the wires are correct when the bike is running.. I'll be very happy to verify that and put the tank on.. Oh yeah... order up a box of lights bulbs too!
Sneezles61
29 Jul 2021 11:25 #8
Replied by MarkT on topic Replacement bulbs, speed&tach
There's a reason you don't have one in your turn signal indicator.  Bulb switches polarity from left to right.
Some LED's are no longer polarity sensitive so can work...  technology has improved.
30 Jul 2021 10:15 #9
Nope, the LED bulb works fine in the turn signal indicator. I was curious as to why I didn't have one there so I switched bulbs, works fine. I guess I didn't buy enough to switch all.
71 Z50 Minitrail
21 CRF300l Rally
30 Jul 2021 10:34 #10
