ct3 frame motor mount.
- ksours
ct3 frame motor mount. was created by ksours
1 of the motor mounts has been worn out. The top of the mount is gone. The mount at the frame is good. Is there a place that sells the mounts to weld on or am I at the mercy of a frame shop?
18 Jul 2021 18:54
Replied by RT325 on topic ct3 frame motor mount.
Gosh, never seen that before. If it was caused by loose engine mount bolt then i'll be she vibrated heaps. If the rest of the frame is solid then a bit of fabricating required or off to an engineering shop which should be an easy job for them--just copy the otherside.
18 Jul 2021 19:13
- Pete-RT1
Replied by Pete-RT1 on topic ct3 frame motor mount.
Any half decent fab shop will be able to sort that out.
Where in the UK are you based?
Yamaha CT3 (in bits)
19 Jul 2021 01:46
- ksours
Replied by ksours on topic ct3 frame motor mount.
Outskirts of Phoenix. The frame is solid and i would like to keep matching numbers. I was afraid that it would take a fab shop. Thanks guys.
19 Jul 2021 06:43
- Youngdrakeo
Replied by Youngdrakeo on topic ct3 frame motor mount.
Even taking that to a fab shop shouldn't cost much. I could fix that in a hour. Fab shop shouldnt charge you more than that. Pretty simple bracket to replacate.
73 CT3 modified, 74 AG175 MX, 79 YB100 x2 , 79 GT 80 ,2015 ducati scrambler ,honda CT70
20 Jul 2021 06:35
