RT1 Newb
  • Geiger
  • Geiger's Avatar Topic Author
RT1 Newb was created by Geiger
Hi everyone. I'm doing my best to restore a RT1 1970 360 and it's coming along really well! I'm looking for someone with more knowledge and experience than me about a couple of unobtainable bits and if there are alternative parts. Firstly, I cannot source a tacho cable at anything like a reasonable price and wondered if any DT cables would fit. It looks like the original was approx 850 - 900mm long, and the ends look pretty standard to me. Also, I could do with a decompession valve cover and a lower chain guard. Anyone know of any alternative parts from other bikes?
28 Mar 2021 12:07 #1
Replied by MarkT on topic RT1 Newb
28 Mar 2021 12:25 #2
It might be me but I have trouble navigating the KDI site sometimes...
Here's a direct link to the cable www.kdirepros.com/Tachometer-Cable-p/214-83560-00.htm
Or they have a complete set of cables for around $73 which is a great deal.
28 Mar 2021 12:32 #3
Replied by Gr8uncleal on topic RT1 Newb
 from the UK.
The decompression cover was also fitted to the RT2, RT3, DT360A (and probably DT400B & C), SC500, MX360, MX400 and YZ400. You can find info on shared parts on sites like Partzilla and CMSNL.
They can be quite expensive if listed individually on fleabay and the like. Conversely, if they are sold as part of a job lot, or attached to a poor condition used cable, they can be quite cheap - spread your net as wide as you can!
28 Mar 2021 12:35 #4
  • Geiger
Replied by Geiger on topic RT1 Newb
OK, thanks for these ideas. I should have mentioned I am in the UK, and a 14$ cable can cost 60ish $ to get from USA or Canada.
28 Mar 2021 14:43 #5
Yep, Mauser, shyted et al and I have all been there and got the overdrafts to prove it!
If the weight of the package will allow and if you ask nicely, some US sellers will change to a cheaper courier service. Also look on ebay.com - even though some sellers' default position is not to offer overseas postage, some are happy to if you ask.
29 Mar 2021 00:39 #6
  • Geiger
Oh, I did message KDI and asked if they had a cheaper postage option, but they were adamant that USPS was cheapest. Then I found a site in Hollywood selling carb kits with postage to UK at about $14, not $60 and still with USPS. I did message KDI with this info but no reply up to now.
07 Apr 2021 12:38 #7
  • Geiger
Anyway, if anyone can spare me a few minutes over the next few days and do a rough measurement of their tacho cable, with screw on fittings at both ends (Yamaha) and let me know which model they have if it's about 950mm I would really appreciate that.
07 Apr 2021 12:41 #8
Replied by Pete-RT1 on topic RT1 Newb
I make the overall length of the inner cable 865mm.
Do you have a photo of your cylinder, I didn't think the RT-1 had a decompression valve until 1971, ie. the RT1-B.
Yamaha CT1 007
Yamaha CT1-B The Doppelgänger
07 Apr 2021 14:05 #9
  • Geiger
I had a look. According to CMSNL diagrammes the RT1 does have a compression valve. Also my engine number states 1970. However I seem to have a RT1B rear light unit. Regardless, the tacho cable drive is in the same position on both, and my measurement was only done with a piece of electrical flex so very approximate. If yours is off a RT1 it gives me an accurate measurement and I can start looking for a replacement from another Yam. Many thanks.
09 Apr 2021 03:45 #10
