Cleaning inside crankcase
- yamahahaha
Cleaning inside crankcase was created by yamahahaha
I'd like some suggestions on cleaning out the crankcase (water,rust,dirt) without taking it apart. What cleaners or solvents to use ???
27 Mar 2021 20:16
Replied by RT325 on topic Cleaning inside crankcase
I'll be the baddie seeing nowone's answered & teach you bad habits but i have in the past waterblasted with bike upside down on its handlebars while revolving the crank. Had conrod hooked to a stretchie to stop it flailing around. Also got the nozzle as best i could into the oil feed hole to the mains so it at least tries to wash anything back into the crankcase & out. Sorry to say but there's no easy answer except pull it apart & do it properly.
The following user(s) Liked this Post: yamahahaha
28 Mar 2021 16:10
Replied by MarkT on topic Cleaning inside crankcase
Crud is one thing (like after a meltdown) but when you mention rust I worry about the big end rod bearing.
It doesn't take much rust and the bearing will fail quickly. When it does, you might get lucky or you might end up like the guy who recently posted on here and a bad rod bearing took out the whole engine... cases and cylinder got destroyed.
28 Mar 2021 16:26
- yamahahaha
Replied by yamahahaha on topic Cleaning inside crankcase
Did I mention it was just a TINY bit of rust
28 Mar 2021 16:48
- Yamadude
Replied by Yamadude on topic Cleaning inside crankcase
Photos !!!
You can just call me Dude.
Syracuse, New York
Syracuse, New York
- Rick C.
Replied by Rick C. on topic Cleaning inside crankcase
Tiny bits can go bad...Quickly !
