DT1 plastic rear fender paint removal
  • type one
  • type one's Avatar Topic Author
  • Platinum Member
  • Platinum Member
DT1 plastic rear fender paint removal was created by type one
Evening
so Ive started work on the  recent '68 Mx conversion I bought ...
the rear fender is a really nice plastic fender in the same shape as the stock metal one or pretty
close in shape ... it needs a few repairs bit
most importantly I want to paint it silver ... it's currently yellow ...
any tips on paint removal and or preparation??
cheers
T1 Evening
cheers
T1
DT1's mainly -
1968 AUS
1969 B scabby track bike
1969 B MX project
73 CT3 project
BMW GSA 2018
15 Mar 2021 14:47 #1
Replied by brigsy on topic DT1 plastic rear fender paint removal
I would try running it under hot tap water, should soften the paint so it can be scraped or peeled off. That's how I removed paint from my 68 tank. I guess you'd have to be careful it's not too hot to deform the plastic.
68 DT1 003325
09 XT250
The following user(s) Liked this Post: MarkT, mdscott
16 Mar 2021 20:08 #2
Replied by MarkT on topic DT1 plastic rear fender paint removal
Brake fluid attacks many paints.  May or may not hurt the plastic.  I used brake fluid to remove paint from a plastic fender and it worked really good...  paint blistered up and wiped off almost immediately.  Plastic was fine.
16 Mar 2021 20:32 #3
  • type one
  • Platinum Member
  • Platinum Member
Replied by type one on topic DT1 plastic rear fender paint removal
Thanks guys I'll try both
Cheers
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
17 Mar 2021 04:43 #4
  • type one
  • Platinum Member
  • Platinum Member
Just to update ....
oven cleaner - no
brake fluid - no
boiling water - yes
thanks
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
The following user(s) Liked this Post: brigsy
19 Mar 2021 07:35 #5
Replied by msavitt on topic DT1 plastic rear fender paint removal
hi all
this is a very helpful thread as i am restoring my new dt1e, which has a dt1mx front fender
once i strip paint how should I prep surface for painting?  what kind of paint is recommended for plastic?
thank you
Martin
19 Mar 2021 10:06 #6
Replied by KennyV on topic DT1 plastic rear fender paint removal
Once plastic is clean you can use this and use pretty much any paint you want.
Klean Strip also make an aerosol spray "Aircraft paint striper" that works good for striping paint from plastic.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
Last edit: 19 Mar 2021 12:45 by KennyV.
19 Mar 2021 12:41 #7
thanks
19 Mar 2021 13:26 #8
