Oil Leaking from the manifold or Muffler connection - DT1
- LuckyLuke
Replied by LuckyLuke on topic Oil Leaking from the manifold or Muffler connection - DT1
Interesting. I checked the 72 DT2 and you're right they added a Part #15 gasket between the manifold and the muffler. This fix is exactly what is needed and relatively easy to do.
perfect! Thanks everyone
06 Mar 2021 03:08
#11
Replied by RT325 on topic Oil Leaking from the manifold or Muffler connection - DT1
yep 15 is just the string packed in the slot for pipe to push against but think that what you mean!!.
07 Mar 2021 00:09
#12
- LuckyLuke
Hey guy I did what you said and it worked perfectly! Thanks again.
The following user(s) Liked this Post: Yamadude
09 Mar 2021 19:08
#13
Replied by Gr8uncleal on topic Oil Leaking from the manifold or Muffler connection - DT1
Who is Guy?!
Glad you got it sorted.
10 Mar 2021 00:18
#14
- asco
Replied by asco on topic Oil Leaking from the manifold or Muffler connection - DT1
If you have persistent oil blowing out of the exhaust with or without the oil injection pump check ball and spring in place. You could very well have a bad crankshaft seal on the clutch side. Surprised nobody mentioned this..
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
- LuckyLuke
Thank you ASCO for your comment. I would like to know more why you believe that a crankcase seal leak may result in a manifold oil leak? I am relatively new at this stuff and always looking to learn more. I had a seal leak on the clutch side and recently replaced all of the seals. That doesnt mean they dont leak anymore; however, I did do a leak down test and it appeared that the lower end was fairly air tight. I have yet to give the bike a full test run and so I would like to hear more about your thinking in case I need to further trouble shoot this issue.
Cheers and thanks again for you comment and feedback....look forward to hearing your response.
11 Mar 2021 16:17
#16
'My opinion only' but crank seals are very robust on those motors. Unless your oil level is disappearing fast on the trans dipstick in my opinion it'll be good. On the smaller motors that right side crank seal can get forced out & let trans oil into the crankcase. Good thinking from 'asco' in #15 though.--& the pump ball & spring.
11 Mar 2021 16:28
#17
- asco
While it is very true that the DT1 seal on the crankshaft side out lasts most AT1's and CT1's by far If you are losing oil on the right side it must to go somewhere. It's not all going to get burned up.
I remember in the past somebody had a bike I believe it was a Suzuki twin that was leaking oil that was not greenish or brownish out of the header. The diagnosis was a crankshaft seal. Just thinking out loud.
a
a
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
