JT1 60 question (rear fender
  • Daygo1966
  • Daygo1966's Avatar Topic Author
JT1 60 question (rear fender was created by Daygo1966
Hello, new to the forum and glad to see this page as I just picked up a JT1. I’m planning on doing a resto and curious about the rear fender. Mine doesn’t not have the holes with rubber grommets. Could this be the wrong fender or repop?
I have yet to search for the serial numbers. Are they both on the frame and motor?
10 Jan 2021 18:30 #1
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic JT1 60 question (rear fender
Welcome! from the UK.
I don't know anything about the JT1, so will leave it for others to answer your question about the rear fender.
I would expect to see a series of letters and numbers on the headstock and also on top of the crankcases - these are the frame (aka VIN) and engine numbers. When the bike was new, these would have been the same. However, over the years, some bikes will have had their engines replaced. If you haven't done so already, check out the Tech Library (see top toolbar) for VIN tables, parts and service manuals etc.
11 Jan 2021 00:04 #2
Replied by Schu on topic JT1 60 question (rear fender
I have four rear fenders in hand for the little JTs, and they all have the holes, although one has been skinned with filler and sanded smooth, so it appears there are no holes, until you look at the underside.
11 Jan 2021 14:49 #3
