DT1 sprocket carrier bearing replacement
  • type one
  • type one's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Help & knowledge needed please
How is this bearing removed ?? Specialist press needed?
What size and specification details do I need to locate a replacement??
T1
DT1's mainly -
1968 AUS
1969 B scabby track bike
1969 B MX project
73 CT3 project
BMW GSA 2018
05 Dec 2020 11:06 #1
Replied by Swoop56 on topic DT1 sprocket carrier bearing replacement
The bearing will knock out with an appropriate drift . If you heated it in an oven
( when your missus isn't around ) , it might shift easier . I'm guessing it's for a
DT1 B , if so the bearing is a 6204 . I'd use a double rubber seal example .
They are readily available at bearing suppliers ( SKF , SAECO , NTN ) .
05 Dec 2020 11:47 #2
  • type one
  • Platinum Member
  • Platinum Member
Replied by type one on topic DT1 sprocket carrier bearing replacement
Thanks Swoop
Out of interest how hot oven temp wise?
150 degrees C?
Cheers
T1
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
07 Dec 2020 06:30 #3
That's probably fine . I've always done them cold myself .
Some people heat heat engine cases when installing main bearings / cranks .
I would guess a similar temperature would work . Hopefully someone else will comment .
07 Dec 2020 11:29 #4
  • type one
  • Platinum Member
  • Platinum Member
It worked a great ... thanks :likey
DT1's mainly -
1968 AUS
1969 B MX project
73 CT3 project
BMW GSA 2018
The following user(s) Liked this Post: MarkT, Swoop56
07 Dec 2020 12:01 #5
