75 or 76 DT250
  • Markb61
  • Markb61's Avatar Topic Author
75 or 76 DT250 was created by Markb61
Although I thought I had bought a 1975 DT250B ,after checking vin it seems to be a 1976 DT250C am I right in thinking the only difference between years is the new Portuguese orange paint?
24 Nov 2020 12:47 #1
Replied by MarkT on topic 75 or 76 DT250
Decals on tanks and pipe heat shield are slightly different too... I think most of the differences are cosmetic?
Some of the experts on that model will hopefully be along to comment.
24 Nov 2020 17:36 #2
Replied by Swoop56 on topic 75 or 76 DT250
The 76 model came with a voltage regulator stock .
That limits the voltage on the headlight , and possibly some others .
Blown headlamps are a frequently recurring issue here on posts .
Hopefully , not a problem you'll encounter .
24 Nov 2020 18:39 #3
Replied by Lizeec on topic 75 or 76 DT250
Another tell tale sign is the 1976 model came factory with a voltage regulator bolted on the air cleaner housing, it is a little metal box with a single yellow wire coming from it, not a fool proof identifier as many upgraded the 1975 models with a 1976 air box and voltage regulator. And as MarkT mentioned the 1976 fonts are different. Some of the differences are the “250” on the fuel tank is “squarish” font while the other 1975 is “roundish”, the 1976 oil tank just says “enduro” the 1975 say “enduro 250” again best bet to identify is serial number sequence as all the things I mentioned are easily changed.
Last edit: 24 Nov 2022 09:23 by Lizeec.
24 Nov 2020 18:42 #4
Replied by garry on topic 75 or 76 DT250
Gedday. Garry here in Australia. Anyone know the year or model of my Yammy? 575-000228. Not shown on the regular sites. Cheers Cobbers and thanks.......K...ooooo w.....eeeee.
24 Nov 2020 20:34 #5
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 75 or 76 DT250
Welcome! from Salisbury, UK Garry. Can you believe that three mates from the small village where I grew up all moved, independently, to Oz? One of them even had a DT125!
Anyway, 575 is the model code for the 1976 DT250C that Yamaha marked the market for as "Others". Looking at the Yamaha model guide, my guess is that Oz and Kiwi bikes were moved by Yamaha from the "Oceania" market into "Others". If you can find a Yamaha service manual for your part of the world, then this may give more detailed info.
Hope that this helps.
24 Nov 2020 23:40 #6
Thanks so much Cobber. Here in Oz in terms of Vintage MX racing we have pre 75 and pre 78. This thing flies! I might even win against the MX's
and YZ's. I also have 465H and 490k and DT250A.
25 Nov 2020 00:00 #7
  • Markb61
Replied by Markb61 on topic 75 or 76 DT250
Yes definitely a 76 c everything you mention is on mine
26 Nov 2020 05:48 #8
Replied by Liebherr on topic 75 or 76 DT250
hi
Please can you help
Where does the yellow wire connect to as it doesn't show on the electrical drawings.
Billy
24 Nov 2022 08:33 #9
Which yellow wire and which year DT250?
There is a yellow (sometimes yellow/white) out of the stator to power the headlight switch...  and a yellow out of the dimmer part of the headlight switch that powers high beam.
24 Nov 2022 09:07 #10
