OIL THREAD!
- RALPH
OIL THREAD! was created by RALPH
The local auto parts store no longer carries Valvolene T4 or 4T, which ever it was I used to use. They do have Shell Rotella T4. Is that acceptable?
07 Oct 2020 11:38
Replied by MarkT on topic OIL THREAD!
Most of the Rotella T line has a JASO MA (motorcycle wet clutch) rating. You should find it on the back label near the bottom if I remember correctly.
I use it in my XT250 and it works great.
en.wikipedia.org/wiki/Shell_Rotella_T
The following user(s) Liked this Post: turbodan
07 Oct 2020 12:17
- turbodan
Replied by turbodan on topic OIL THREAD!
I have run Rotella T4 15w40 in everything from a 125cc two stroke up to a 600cc inline four. Blackstone has confirmed that it does an excellent job with multiple samples analyzed.
Its a very good choice, doesn't hurt that it is $14 a gallon.
- RALPH
Replied by RALPH on topic OIL THREAD!
Thanks for the info. It's $19/gal here.
07 Oct 2020 17:46
Check Walmart. Usually $14 or less.
07 Oct 2020 19:55
- asco
Replied by asco on topic OIL THREAD!
My choice bought at Cycle Gear. It's a synthetic blend at $9.95 a quart. I like oil threads, their better than ordinary sultry posts...
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
08 Oct 2020 20:58
- Delcowizzid
Replied by Delcowizzid on topic OIL THREAD!
I run this stuff in my 78 dt the clutch loves it I do a lot of clutch slipping doing hard enduro riding and the clutch gets a hammering no slip no shuddering
09 Oct 2020 15:50
