Part ID, 1976 DT125
- MikeBike
Part ID, 1976 DT125 was created by MikeBike
Hi folks,
Looks like we broke this part after a drive chain break, haven't been able to name it/identify it. When intact it was a white plastic dome, the image now shows just the rim held in place by the three phillips-head screws.
Let us know if you can name it, and maybe where we can get one: 1976 DT125. Any assistance is greatly appreciated.
Thank you!
Mike & Isaac
(Note: looks like image is rotating 90ยบ CW)
Thank you!
Mike & Isaac
Slow down, we're in a hurry.
- Enduronut
- Founder Moderator
Replied by Enduronut on topic Part ID, 1976 DT125
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=184040064090&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- MikeBike
Replied by MikeBike on topic Part ID, 1976 DT125
Enduronut -- Thank You!
mh
mh
30 Aug 2020 06:53
Replied by MarkT on topic Part ID, 1976 DT125
Make sure you didn't lose the washer and horseshoe clip that locates the shift drum. (#8 and #9)
Without them, the bike won't shift right and could actually damage the transmission.
www.partzilla.com/catalog/yamaha/motorcy...t125c/shift-cam-fork
Also, rotate the clutch pushrod (right in front of the sprocket) to make sure it didn't get bent. Should spin without any wobble.
30 Aug 2020 07:50
