1965 YM1 Gas tank petcock
  • sgarvin0711
  • sgarvin0711's Avatar Topic Author
1965 YM1 Gas tank petcock was created by sgarvin0711
I need to clean out the gas tank and eventually get it painted. How do I remove the petcock?
06 Aug 2020 17:14 #1
Replied by swm on topic 1965 YM1 Gas tank petcock
Remove threaded bowl, remove round strainer, remove 3 JIS screws - DONE.
06 Aug 2020 18:29 #2
  • sgarvin0711
Replied by sgarvin0711 on topic 1965 YM1 Gas tank petcock
Thanks! Just what I needed. There are 2 pieces of rubber... 1 is an O-ring under the bowl and one is under the valve handle. Both seem to be in excellent condition, but should I replace them just based on their age?
11 Aug 2020 13:16 #3
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=114253769298&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • sgarvin0711
You are my new best friend!
Just curious. Why replace the ones on the banjo bolts? They are hard and don't move. Can they wear out?
Should I also replace the strainers if they also seem to be in good order?
12 Aug 2020 15:13 #5
I replace banjo bolt washers as they harden over time which can create another opportunity for fuel leak.
If strainer is not damaged I'd reuse it.
12 Aug 2020 18:53 #6
