1975 DT175 Won't Start
- Renegade578
Replied by Renegade578 on topic 1975 DT175 Won't Start
The seal is at least 1/16th out from the case, maybe even 3/32nds.
07 Dec 2022 08:56
#31
Replied by Ht1kid on topic 1975 DT175 Won't Start
How much thicker is it than your original one I use the IT 175 seals on my Ct1c like MarkT recommends because of the dual lip
07 Dec 2022 15:17
#32
Replied by MarkT on topic 1975 DT175 Won't Start
Both styles OEM seal are 8mm thick.
Might have broken a ring or sucked in a reed?
07 Dec 2022 19:45
#33
- wfopete
Replied by wfopete on topic 1975 DT175 Won't Start
I really like these older on/off road bikes (1978 DT175) but I tell you they were sure put together like crap. AFAIK there is no way to align the exhaust head pipe gasket to the cylinder or the pipe; you just eyeball it and hope it stays in place while the pipe get tightened down. A dab of grease will help but still, what a weak design.
08 Dec 2022 10:26
#34
WFOPETE.... exhaust to cylinder gasket is a ring that fits solidly and securely into a recess machined into the cylinder. Perfect alignment. Maybe you still have an old gasket installed?
The following user(s) Liked this Post: AirborneSilva, Schu
08 Dec 2022 11:49
#35
Back to the original thread from the thread hijack...
Metal in the oil drained is the transmission/clutch. Not sure what scraping sound could be. Did engine still run? Was scraping while riding or when stopped or both?
08 Dec 2022 11:53
#36
- Renegade578
The engine still runs. I will try to post a video tomorrow of what it sounds like. As soon as I installed the crank seal, I started hearing a squeak when turning it over. I thought the squeak went away when I ran it for 5-10 minutes while tuning the carb. When I rode it around the block it died and that’s when the rubbing sound started. The squeak is still there. I think I’m going to have to pull the head and inspect the rings and cylinder walls. I looked inside through the spark plug hole with an endoscope, but didn’t see anything obvious.
08 Dec 2022 18:38
#37
This is a wild guess do you think it’s the magneto scraping possibly your source or lightning coil video will be great do you have mechanic stethoscope to help find the problem
- Renegade578
Here are 2 videos. One is me kicking it with the run switch off so you can hear the noises. The other is it actually running. The reason it's smoking so much is because I put some 2 stroke oil directly in the cylinder to lube it up.
www.youtube.com/shorts/c6FPOSq5rC0
www.youtube.com/shorts/0iVznSsdgjk
- wfopete
I'm not sure which or both crank seals were replaced but I wonder if you may have a clutch hub nut, primary gear nut or flywheel nut not fully seated. The sound of the condition isn't very clear in the video. Sounds like a "Whirring" noise which to me indicates a clutch basket/primary gear sound.
09 Dec 2022 07:44
#40
