Oil pump check ball rubber seat
Replied by MarkT on topic Oil pump check ball rubber seat
I thought I read in that RZ thread someone DID say they put it on the inlet. That's not how the metal one I gave the part number to is designed. It goes in outlet.
Here is a post from GFrench mentioning he installed an external check valve since his pump leaked. You can see it in the video. Looks like a metal one?
yamaha-enduros.com/index.php/forums/rest...-one?start=170#69536
31 Oct 2022 19:41
#11
- GaryDean
Replied by GaryDean on topic Oil pump check ball rubber seat
Thanks MarkT
Yes I seen it, I have ordered the part number you gave me from my local yamaha dealer, will look fwd to a fix I hope.
i may try and see if I can squeeze it in the side casing with the pump, but wont know till it arrives
01 Nov 2022 05:38
#12
- GaryDean
I got the check valve and did a temp set up to see if any weeping, 3 days later and no weep, so I have now installed it and managed to get it in the oil pump casing
Ive set another test pipe at carb end to check again for weeping in a weeks time, if ok will button it up
Thanks go to MARKT fore knowing the info on the external valve and for giving me the info. I would of been stuffed without it, thanks again for your help.
The following user(s) Liked this Post: MarkT, Ht1kid, Pete-RT1
06 Nov 2022 05:42
#13
- AirborneSilva
Replied by AirborneSilva on topic Oil pump check ball rubber seat
GARYDEAN do you have the part number for the check valve? Somehow I missed it, would like to get one to keep on hand encase any of mine decide to not cooperate. Thanks, Tony
06 Nov 2022 07:59
#14
- GaryDean
Hi part number is 8CH-1316A-00
£27 in uk and it worked. I removed the old spring n ball from the pump
no more smokey starts!! It got to the point of wiping the area out with smoke, hopefully now all back to normal
06 Nov 2022 08:11
#15
- AirborneSilva
Thank you...
06 Nov 2022 08:16
#16
