74 dt250 plastic side cover for racing?
  • Jbeebe
  • Jbeebe's Avatar Topic Author
Hey guys,
I'm building a 74 dt250 for racing. In the process I will be losing the steel oil tank and I'd like to put a cover/number plate on the side to prevent the filter from getting covered after 10 seconds. Anyone know if the right side mx panel here will fit: www.dcvmx.com/xcart/product.php?productid=18538&cat=283&page=1
Or maybe some ideas of what you did? I'll be running just a standard uni-style foam filter right off the carb, just to give you an idea of space.  I guess I could just zip tie an oval number plate to the side or weld tabs with a nut on the back on the frame tubes a use bolts, but a little more refined would be nice.
Thanks for the guidance!
16 Dec 2021 08:05 #1
  • Schu
  • Schu's Avatar
Replied by Schu on topic 74 dt250 plastic side cover for racing?
Mine are zip tied to the frame tubes. I run the same filter set up you described.
The following user(s) Liked this Post: Sneezles61, adguy2112, chuckw
16 Dec 2021 09:05 #2
Replied by Scootern29 on topic 74 dt250 plastic side cover for racing?
You may want to look into side plates for a 76 YZ 400. With a little trimming they may look and cover much better.
The following user(s) Liked this Post: Rick C., MarkT
16 Dec 2021 09:31 #3
  • Jbeebe
Replied by Jbeebe on topic 74 dt250 plastic side cover for racing?
looks great. I appreciate the pics to help visualize it.
17 Dec 2021 04:42 #4
  • Jbeebe
Thanks for the tip!
17 Dec 2021 04:44 #5
