electric problems YAMAHA DT 250, Typ 512, 1975
- Knuth Fischer
electric problems YAMAHA DT 250, Typ 512, 1975 was created by Knuth Fischer
Hi from Germany,
does anyone has a wiring diagram for a 1975 YAMAHA DT 250 Typ 512 (with RESISTOR)?
In my org. YAMAHA workshop manual (printed end of 1974) for the DT 250 B there is a diagramm without a resistor (1975, part-no 456-85370-42) or a voltage regulator (1976, part no 489-81910-60). In the YAMAHA PARTS LIST (FOR EUROPE) 1975 and 1976 the parts are shown.
I bought the bike years ago and now the restauration is nearly finsh. From UK I got a repro wire harness but it dont fit correct. The wire colours are different aso. It seems that some electric parts are for the 1976 Version, other parts are for the 1975 version.
Sorry for my bad English. i learned it 45 years ago in a German School.
Best Regards
Knuth
Best Regards
Knuth
The following user(s) Liked this Post: retired jet mech
21 Jul 2020 10:09
Replied by Gr8uncleal on topic electric problems YAMAHA DT 250, Typ 512, 1975
Knuth
I posted a wiring diagram on your earlier thread, was this no good to you?
21 Jul 2020 10:56
- Wessi
Replied by Wessi on topic electric problems YAMAHA DT 250, Typ 512, 1975
Hi Knuth, regards from Germany as well
Have a look on this post, i had the same Problems. The UK harness, i couldn´t use as well, so finally i decided to convert to US harness including US main switch with just on/off.
Works fine and is legal.
yamaha-enduros.com/index.php/forums/74-7...-4-positions?start=0
Guido
Guido
21 Jul 2020 22:45
- Knuth Fischer
Replied by Knuth Fischer on topic electric problems YAMAHA DT 250, Typ 512, 1975
Hallo Guido,
Thanks for your help! I also thing About using a new aftermarket main switch with only on/off positions. But the German TÜV will see the "Standlicht" for itselfe without "Fahrlicht". How do you solfe this?
Regards from northern Hessen
Knuth
Knuth
21 Jul 2020 23:20
- Wessi
Hi Knuth,
I connected the stand light to the tail light. Means main switch on-stand light on. Headlight only works, when motor is running, so ok for bi-annual technical check up.
If you go for US wiring, you have to change or modify left handle switch, too.
Br Guido
Br Guido
22 Jul 2020 10:23
- Knuth Fischer
Hi Guido,
in this way is it possible to drvie the DT with switched off stand light/head light/tail light?
Regards
Knuth
Regards
Knuth
22 Jul 2020 10:34
- Knuth Fischer
Hi all together,
sometime luck helps. I found a org. YAMAHA DT 250/400 supplement for the workshop maual - with the correct wire diagram (main switch 10 wires)!!! Also the repro wire harness from UK I bought now fits right!
So the target comes nearer that the DT will smoke blue fog in the future.
Best Regards
Knuth
Best Regards
Knuth
04 Aug 2020 08:00
Great news Knuth!
Was it a Yuni Parts/Yuni World harness? A shame they closed down, although when I "Googled" them to see what had happened, an industrial tribunal instigated by a former employee came up!
- Knuth Fischer
Hi Gr8uncleal,
sorry, it is years ago when I bought the wire harness.
I only remenber that it was from UK. The company I don't know.
But it works.
Best Regards
Knuth
But it works.
Best Regards
Knuth
10 Aug 2020 09:43
