Cylinder barrel oil line fitting.
  • djetmb
  • djetmb's Avatar Topic Author
Cylinder barrel oil line fitting. was created by djetmb
I acquired a CT 2 last fall that had been off the road for some time and was not in running condition. It's now running and I'm sorting out
some details. Regarding the oil line fitting on the barrel, mine has the bolt with the tapered tip installed. The parts fiche on the CMSNL
website  shows the straight bolt with no tip.
Can anyone confirm this? I do have a straight bolt in my stash so easily changed.
There is no evidence of any cylinder bore or piston damage.
Thanks for any help.
20 May 2024 15:34 #1
Replied by RT325 on topic Cylinder barrel oil line fitting.
Not sure what you mean by tapered tip which sounds like a bolt to locate into something. Is it hollow. CMSL for CT2 shows the usual bolt on my computer.
20 May 2024 15:48 #2
Unless it's a longer than normal stepped down hollow bolt with extended nose out of something else to put the oil out into the airflow.
20 May 2024 15:50 #3
Replied by automan on topic Cylinder barrel oil line fitting.
Sounds like a M6 brake fitting to me.
cliff
21 May 2024 08:24 #4
  • djetmb
Replied by djetmb on topic Cylinder barrel oil line fitting.
I replaced it with the straight bolt listed. The tapered bolt that was in there is a Yamaha part. It is
hollow and has a very small outlet hole. Thanks for the input.
21 May 2024 11:36 #5
