Were early CT2 bikes identified as CT1's?
  • landyr67g
  • landyr67g's Avatar Topic Author
A friend is looking at a rough CT1 that was sitting outside in desert for 20 years. Frame, case, and original sticker numbers matching with s/n 09025# which puts it and of CT1 series.  That said, I think the sticker reads 3/72, and the bike is the dark candy red color with CT2 tank, reed valve, torque induction oil tank.  Head/cyl/side covers and carb are CT2.  High starter switch.
Thanks for any info.
Regards,
Joe M
('70 CT1 project)
22 Apr 2024 10:05 #1
Replied by Gr8uncleal on topic Were early CT2 bikes identified as CT1's?
That number is for a CT2 (if I've read the VIN table correctly!).
22 Apr 2024 10:26 #2
  • landyr67g
Replied by landyr67g on topic Were early CT2 bikes identified as CT1's?
Forgot to mention the numbers (Frame stamp, faded sticker, engine stamp) all are stamped CT1 - 09025x (x = a real number). In the AT1-CT1 parts list .pdf (in site docs) this number is a CT1C number (up to 200101) and Orange color. Some errors somewhere?
Regards,
JoeM
22 Apr 2024 11:43 #3
Replied by MarkT on topic Were early CT2 bikes identified as CT1's?
All USA 175's from 1969 to 1973 had a CT1 prefix.  The "200101" range of numbers you're referencing belongs only to the special "close ratio transmission" 1971 CT1c model...  the "2" at the start sets it apart from the standard CT1c that year.
CT1-065101 to 098830 was the range for the CT2 model.
VIN tables can be found in the Tech Library
22 Apr 2024 11:53 #4
  • landyr67g
Ok Guys - Thanks for explanation re. the VIN table. Also implies there were ~8,500 red 175's made after this one for '72.
Regards,
Joe M
22 Apr 2024 14:17 #5
Replied by RT325 on topic Were early CT2 bikes identified as CT1's?
CT3 were still CT1 numbers till the end? then the A models came from "74 with a total design change. Just sayin.
23 Apr 2024 16:23 #6
