DT3 Detent plunger
- Tim Ravic
DT3 Detent plunger was created by Tim Ravic
I've recently got a DT3 imported from USA, which I'm starting to restore. I've stripped the engine and have discovered that the gear selector detent plunger & spring are missing. There is some small scraps of metal in the gearbox but nothing else looks damaged. I'm in the UK & have looked for the parts but they don't seem to be available. Does anyone know if any later/other model parts would work? Thanks
22 Sep 2023 04:11
Replied by Gr8uncleal on topic DT3 Detent plunger
There is one listing for each currently on fleabay - see links below.
Yamaha XS2 XS650 TX750 DT1 RT1 YR1 YR3 YA6 TR2 cam stopper pin 137 18547 00 | eBay
YAMAHA DT3 RT2 RT3 1972/1973 GENUINE NOS GEAR SHIFTER SPRING - # 90501-10066 | eBay
22 Sep 2023 04:51
- Tim Ravic
Replied by Tim Ravic on topic DT3 Detent plunger
Thanks for that... I've bought them.
Do you know if there is an issue with these breaking?
22 Sep 2023 05:19
Not breaking as such, but if there is water ingress on a bike abandoned outside, say, then the spring can rust (it happened on my US import RD350). Saying that, there will be other signs of the water ingress as well.
What is more usual is for owners to mistake the detent holding bolt as the oil sump drain bolt
and the spring and stopper get chucked out with the old oil!
The following user(s) Liked this Post: Rick C., MarkT, Ht1kid
22 Sep 2023 05:29
- Tim Ravic
Blimey... you're probably right there. Yikes!!!
Thanks for your help.
22 Sep 2023 05:33
I'm not sure how many of the old posts you've read, Tim, but I would recommend fitting a 6v regulator if you're sticking with original electrics. Post if you need more info.
22 Sep 2023 06:39
- Tim Ravic
I will be using this site for the many questions that will, no doubt arise.
22 Sep 2023 06:53
Replied by Ht1kid on topic DT3 Detent plunger
Greetings from Tennessee
Change your brake shoes before you ride your bike for safety reasons
The following user(s) Liked this Post: MarkT, Gr8uncleal
"Change your brake shoes before you ride your bike for safety reasons."
+1
They are still available from Yamaha - check CMSNL for the up to date part numbers.
If you need them, KDI on this site sell repro cables (amongst other items) and forum moderator/member DEET sells top notch replacement silver/grey wire sleeving.
+1
22 Sep 2023 08:03
Replied by RT325 on topic DT3 Detent plunger
Just a thought. Did you drain the oil yourself out 'that' bung instead of the middle one, as the missing parts could be in 'your' oil tray. Just saying.
