Question on 1973 RT 3 carb
  • Wildcat
  • Wildcat's Avatar Topic Author
Question on 1973 RT 3 carb was created by Wildcat
Gas comes through the small nipple on the bottom of the carb.
this happens when I shut off the bike or turn on the pet cock.
What would the cause of this be and what can I do to make it quit?
thank you.
06 Jun 2023 18:51 #1
Replied by SKYDANCER46 on topic Question on 1973 RT 3 carb
Needle valve assembly worn or dirty. Or float is defective or out of adjustment. Romove carburetor take float bowl off and inspect and clean. You can still buy the needle valve assembly from Yamaha. See service manual here in tech library for float adjustment and specs and other info on the carburetor.
06 Jun 2023 19:00 #2
Replied by RT325 on topic Question on 1973 RT 3 carb
Might be as simple as some rubbish stuck in the float valve--if you're lucky.
06 Jun 2023 19:18 #3
  • Wildcat
Replied by Wildcat on topic Question on 1973 RT 3 carb
Thank you very much.
06 Jun 2023 20:02 #4
