AT2MX - Kill Switch Wiring
- PFC
AT2MX - Kill Switch Wiring was created by PFC
Hello - I am looking for the wiring detail of the magneto wires so I can correctly wire in the kill switch circuit.
I have looked in my Chilton's manual and on the factory manual I have found here on but I don't see any detail of that specific circuit or identification of what the other wires are in the wiring loom.
thank you.
thank you.
16 Feb 2023 09:09
Replied by MarkT on topic AT2MX - Kill Switch Wiring
Tee a wire into the small black wire from stator to coil.
Install a button that grounds the wire you installed when you press it to kill the spark.
Done
Done
16 Feb 2023 11:54
- asco
Replied by asco on topic AT2MX - Kill Switch Wiring
Like Mark said; slice the wire coating off the coil wire
( black ) 1/4” or less carefully with a razor blade. Wrap any wire around that and black tape. Run that wire up to the handlebars with your kill button clamped on either side whichever is more comfortable. It’s really simple.
You should be able to search ( minibike kill button ) or motorcycle kill button ) you only need a one wire button.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
17 Feb 2023 06:37
- DEET
- Moderator
Replied by DEET on topic AT2MX - Kill Switch Wiring
Remember, when someone mentions “coil wire” they are not talking about the spark plug wire attached to the coil.
The following user(s) Liked this Post: RT325, asco, Ht1kid
17 Feb 2023 16:26
Replied by RT325 on topic AT2MX - Kill Switch Wiring
Spark plug wire would make ya hair stand on end.
Just crimp a double connector female in place of the single female on the black as it connects to the coil. Also depending how well your handlebars are earthed [powder coated bars could resist earthing] it could be good to have a separate earth from the button to somewhere frame--like coil mount loom earth. Even that could end up not working with coated bars if the button earths by center touching the bar when pressed, but not sure if any were like that. Getting off track again--chrome bars & you'll be fine.
