73 125 mx cylinder identification
  • zestycj7
  • zestycj7's Avatar Topic Author
73 125 mx cylinder identification was created by zestycj7
Hey everyone. I just picked up a 73 125 mx and need some help indentifing the cylinder that is on it.I was told the enduro cylinders have no part number and the mx does,
26 Jan 2023 12:10 #1
Replied by MarkT on topic 73 125 mx cylinder identification
What numbers did you find?
If I remember correctly both Enduro and MX reed cylinders have displacement (123cc) cast in on lower edge by transfers and I think both have a "code" cast in someplace... lower edge again or often around the intake area... that identifies the model.
Maybe something like 318 or 31800?
26 Jan 2023 13:46 #2
Replied by Ht1kid on topic 73 125 mx cylinder identification
Greetings from Tennessee.
26 Jan 2023 15:56 #3
Replied by RTD2 on topic 73 125 mx cylinder identification
I have a NOS MX Cylinder on my 73 125 MX, I will go check.
Mike
26 Jan 2023 17:06 #4
I see nothing stamped on the cylinder except 123cc.  I will try to dig out my original cylinder and see if there is anything visible on that.
Mike
26 Jan 2023 17:16 #5
It's possible there are no markings... not sure exactly when Yamaha started adding model numbers to casting.
26 Jan 2023 18:46 #6
Mark, I will dig out the original cylinder tomorrow and look. It is so damn cold here right now, that I didn't want to dig into my parts tonight. I will turn on the heater in my shop tomorrow morning and look. I will have a definitive answer, the cylinder I took off was the original.
Mike
26 Jan 2023 19:01 #7
All, I dug out the original cylinder from my 73 AT3MX and the only stamping is the 123cc on the base. It does have a huge intake port BTW!
Mike
27 Jan 2023 10:01 #8
  • zestycj7
Replied by zestycj7 on topic 73 125 mx cylinder identification
Mike, thanks for digging the cylinder out. Sorry about not posting sooner. Life got real busy.
I got a cylinder off a guy that told me it was for an MX, it has a number cast into the bottom of the cylinder, it is #31602. The stock GYT cylinder that came on my bike has no numbers other than the  123cc. I have the porting layout for the Enduro and MX and checked both cylinders. The GYT cylinder ports match the dimentions for the MX and the other matches the Enduro dimentions. The GYT cylinder also has the fins cut back so the expantion chamber is tucked up close to the engine. I put the #31602 cylinder on the bike and the pipe will not fit without hitting the cylinder.
I also noticed the the #31602 cylinder has no hole in the side of the intake for the oil injection line but on the GYT cylinder there is a hole for the banjo bolt.
This whole thing has given me a headache...LOL
I just need to find some where that might have a part number listed for the #31602 cylinder.
24 Jun 2023 08:21 #9
My best guess since you said the cylinder has:
-31602
-no oil injection port drilled at base
-enduro porting
-fins not cut for pipe
is that you have a 1976 DT125C cylinder
The following user(s) Liked this Post: RT360Fan
Last edit: 24 Jun 2023 11:40 by MarkT.
24 Jun 2023 08:43 #10
