73' RT3 360 engine install
- Dirtdad55
73' RT3 360 engine install was created by Dirtdad55
Newly acquired RT3 and I took off the head and cylinder and removed the engine, Question for the group : Can the engine be re-installed
into the bike with the head and cylinder installed ? or do you have to leave the cyl and head off ? Engine is nearing completion and I'm not sure if I should continue reassembly ? Thanks in advance for your input .
10 Nov 2022 13:14
- run103
Replied by run103 on topic 73' RT3 360 engine install
yes put it together on the bench and install as 1 piece. done it 3 times
Doug
Doug
10 Nov 2022 15:46
- Dirtdad55
Replied by Dirtdad55 on topic 73' RT3 360 engine install
Thanks Doug appreciate it
10 Nov 2022 17:35
Replied by RT325 on topic 73' RT3 360 engine install
Some people "Me" lol, find it easier to fit the lower half minus top end just because ya not dealing with so much weight & juggling to get it in with frame top tube getting in the way. Whatever is best for you is my answer.
The following user(s) Liked this Post: MarkT, AirborneSilva, Ht1kid
12 Nov 2022 14:33
