73 RT3, not shifting.
  • Jeep20
  • Jeep20's Avatar Topic Author
73 RT3, not shifting. was created by Jeep20
So I got the bike tore down after the auction. At first I thought the engine was seized, fortunatly this was not the case. After removing the cover and turning the crank I found the piston did indeed move. The kick start will move if pressure is applied while the crank is being turned, travel is limited. The shifter itself feels between gears if that make's any sense. Can't find the gear up or down. The bike was dropped a couple time's in the past. the shifter clearly took a hit as it was bent. Any idea's gentlemen? There's not chunky drag/metal bits in the movement, but its not smooth either.
Last edit: 07 Nov 2022 13:16 by Jeep20.
06 Nov 2022 02:30 #1
