CT2 Mystery Washer / Right side crank cover
- bhsdriller
CT2 Mystery Washer / Right side crank cover was created by bhsdriller
Was pulling the right side cover off to change the clutch discs and heard a washer fall. This was sitting at the bottom of the cover when I pulled it out. Any idea of where it might go? Or am I imaging things and it came from somewhere else lol
24 Oct 2022 08:36
- Pete-RT1
Replied by Pete-RT1 on topic CT2 Mystery Washer / Right side crank cover
It fits on the end of the plastic helical drive for the tacho, the white gear in your last photo
Yamaha CT3 (in bits)
The following user(s) Liked this Post: MarkT, asco, Bdee, bhsdriller
24 Oct 2022 09:32
- bhsdriller
Replied by bhsdriller on topic CT2 Mystery Washer / Right side crank cover
Awesome thanks for the quick response!
24 Oct 2022 09:48
- bhsdriller
When I took the cover off originally the kick start shaft/mechanism came with it. I put it on and it's on in that pic but when I put the case cover back on and tightened the bolts the kick start got hung up and wouldn't return to resting.
If I loosed the cover bolts some it would free up and operate normal.
Is there a special way to install it? I'll try and get a better pic later
28 Oct 2022 11:49
- Pete-RT1
On the second photograph it looks like the washer on your kickstart shaft has an oval inner diameter.
I wonder if it has worn over the years and after the cover was removed and replaced is not sitting true causing the cover to pinch/compress the shaft assembly when you screw the cover on.
Has the inner boss on the cover worn to leave a lip.
Someone else recently added the washer and had a similar problem with the kickstart not returning, I believe they eased/filed the boss on cover.
Another though, did you replace the cover gasket and if so was it an OEM gasket, some aftermarket gaskets are thinner?
The following user(s) Liked this Post: bhsdriller
28 Oct 2022 14:17
- bhsdriller
Thanks I'll review later and report back. It was an aftermarket gasket set
www.ebay.com/str/kishmotorsports
- Dennis D
Replied by Dennis D on topic CT2 Mystery Washer / Right side crank cover
Is the kicker gear spring in the groove in the case? Is the kicker axle stop against the case stop? Not that it will affect the return of the kicker, but you have some serious grooves in your clutch basket fingers. As noted above, the shim on your kicker gear looks like it has a lot of wear on the id.
Your kicker gear and the kick idler gear should not be engaged when in the up position.
