Engine rebuild
  • 45chop
  • 45chop's Avatar Topic Author
Engine rebuild was created by 45chop
Hi all, I’m new here, just rebuilding a 1972 dt 360 rt2 in the Uk. Engine was seized and I’m struggling for some parts. I’ve done the bottom end, new bearings, just waiting for seals. I’d like a new piston kit but that seems not to exist. Currently 2nd oversize and not too bad condition. I’ve ordered new rings and I’d also like to replace the small end bearing. Can anyone give me the correct part number and a link to buy replacement ?
Thanks in advance. Hi all, I’m new here, just rebuilding a 1972 dt 360 rt2 in the Uk. Engine was seized and I’m struggling for some parts. I’ve done the bottom end, new bearings, just waiting for seals. I’d like a new piston kit but that seems not to exist. Currently 2nd oversize and not too bad condition. I’ve ordered new rings and I’d also like to replace the small end bearing. Can anyone give me the correct part number and a link to buy replacement ?
Thanks in advance.
02 Oct 2022 11:52 #1
Replied by Rick C. on topic Engine rebuild
Hello and Welcome from Sunny So. Cal !
BEARING
93310-218A6-00
I know Partzilla has them in stock $22.73 us.
www.partzilla.com/catalog/yamaha/motorcy...972/rt2/crank-piston
don't know about CMSNL near you.
The following user(s) Liked this Post: 45chop
Last edit: 02 Oct 2022 12:27 by Rick C.. Reason: forgot an "N"
02 Oct 2022 12:02 #2
Replied by Gr8uncleal on topic Engine rebuild
 from near Salisbury, Wiltshire.
Online parts lists are available at CMSNL (Holland) and Partzilla (US). There will also be various manuals in the Tech Library on this site (see top toolbar).
If you're intending to run the lights and sticking with the original 6v system, then be sure to fit a 6v voltage regulator (see attached for details). The original document is available for download in the Tech Library.
Whilst the barrel is off, make sure to clean out the hole for the decompression valve.
The following user(s) Liked this Post: Rick C., 45chop
Last edit: 02 Oct 2022 12:15 by Gr8uncleal.
02 Oct 2022 12:13 #3
This message has an attachment file.
  • 45chop
Replied by 45chop on topic Engine rebuild
Thanks, much appreciated from rainy London
02 Oct 2022 12:27 #4
  • 45chop
Amazing, thanks for the tips. The barrel has had the decompression port blocked and a plug in the barrel, not sure I want to mess with it, given how rare parts are. I’ve purchased a universal decompression valve to go in the 2nd spark plug hole to resolve the problem for now.Amazing, thanks for the tips. The barrel has had the decompression port blocked and a plug in the barrel, not sure I want to mess with it, given how rare parts are. I’ve purchased a universal decompression valve to go in the 2nd spark plug hole to resolve the problem for now.
02 Oct 2022 12:35 #5
Last edit: 02 Oct 2022 12:51 by Rick C..
02 Oct 2022 12:42 #6
  • 45chop
Thanks, I’ve just  found it on Yambits even cheaper
02 Oct 2022 13:03 #7
Replied by Pete-RT1 on topic Engine rebuild
Fowler’s have oem bearing in stock.
www.fowlersparts.co.uk/search/part/93310-218A6-00
Always worth checking with main dealer
Yamaha CT3 (in bits)
The following user(s) Liked this Post: MarkT, 45chop
02 Oct 2022 14:21 #8
Replied by RT325 on topic Engine rebuild
Welcome from NZ. Is that blank off long enough to block the hole through at the cylinder. hole comes out then straight down to exhaust port outlet. Be easy to blow or squrt something each way to see. If not totaly blocked it'll feel soft on the kick start. I put a ball bearing bigger than the hole & a bolt to lightly compress it to the hole. In saing that, in my opinion, it won't kill it if its open constantly. Many models like out AG175 & even RD400's had an open hole with no valve. But was drill steeply to get direct to the port outlet. Did that on my YZ465G for enduro riding to help starting when i'm lying totaly Stuffed on the handlebars & out of energy haha. Sorry, digressing. There's many piston kits that should work like later DT360A etc. As usual i'm happy to be corrected--or scolded & corrected.
02 Oct 2022 21:36 #9
"Fowler’s have oem bearing in stock.
Always worth checking with main dealer"
Yes. Sorry, forgot to mention that it is still available from Yamaha and will likely be cheapest if you can order it from your local dealer. Won't even have to be a Yamaha dealer, as I think that Fowlers are the wholesalers that most UK bike shops use.
Yambits looks like pattern - probably OK, but I prefer original if available.
When you post photos, insert them individually to prevent duplication (just a quirk of the system).
02 Oct 2022 23:47 #10
