Shifter shaft seal
  • dubepj
  • dubepj's Avatar Topic Author
Shifter shaft seal was created by dubepj
Fixing a 1973 RT3.  Just waiting on a carb gasket and a Petcock rubber. Put new oil in tranny and noticed a small leak at the shifter shaft seal.   Can I replace the seal without splitting  the  engine.  Sometimes you can pull old seal by screwing a screw and pulling it out??  Any advice is well come.
07 Aug 2022 11:18 #1
Replied by darinm on topic Shifter shaft seal
Yup it's just like you say, you can pull it out with a screw, pick, or modified screwdriver.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
07 Aug 2022 11:38 #2
  • dubepj
Replied by dubepj on topic Shifter shaft seal
Thanks Darinm. Now I'll see if My Local Yamaha store has one. Should I drain oil first or can I just lean bike over??
07 Aug 2022 14:13 #3
Replied by AirborneSilva on topic Shifter shaft seal
I changed mine on my DT2 not long ago, was really easy and didn't have to lean bike over.  Make sure you clean you seat really well.
07 Aug 2022 16:13 #4
I just lean em over
1972 Yamaha CT2 175
1997 BMW R1100R
2013 Yamaha XT250
07 Aug 2022 16:30 #5
Replied by Le7316 on topic Shifter shaft seal
Instead of shifter shaft seal ...im replacing my countershaft seal of the 72 LT2 hehehe.
18 Aug 2022 12:07 #6
Might as well replace the shifter shaft seal while you're there.  Just a thought...
18 Aug 2022 12:16 #7
Previous owner already replaced all 3 but i guess he just didn't do a really good job on Countershaft one. I've checked other seals. Good to go.
18 Aug 2022 12:32 #8
Well that's a good reason to not change it
18 Aug 2022 13:28 #9
