RT2 Magneto Puller - Motion Pro
- Midge0z
RT2 Magneto Puller - Motion Pro was created by Midge0z
Hi Guys, does anyone know the correct Motion Pro Part Number for a Magneto Puller for an RT2 ? Thanks
11 Jul 2022 15:45
Replied by MarkT on topic RT2 Magneto Puller - Motion Pro
By memory 08-0026
27mm x 1.0 LH
27mm x 1.0 LH
11 Jul 2022 16:25
- Makotosun
- Administrator
Replied by Makotosun on topic RT2 Magneto Puller - Motion Pro
Here is our site amazon associates link for the correct puller for the RT2 and most every Yamaha enduro except for the 125 electric start models:
amzn.to/3PdgUII
amzn.to/3PdgUII
11 Jul 2022 23:08
New one on me Mauser. I've never seen any Yamaha magneto use a bolt like that. Yamaha outer rotor magnetos on the two strokes use the same puller from 1964 to 2022 as far as I can tell.... 27mm x 1.0 LH piece threads into the flywheel and then a center push bolt pops it off.
Inner rotor Yamaha magnetos use a sort of "hollow nut" to remove. Those ignitions were used on race machines with no lights/charging system.
Armature on a generator (125 e-start for example) or armature on an alternator (RD350 for example) can use a simple bolt but normally 10mm on a Yamaha.
The following user(s) Liked this Post: Makotosun, RT360Fan, Ht1kid
12 Jul 2022 04:36
- RT360Fan
Replied by RT360Fan on topic RT2 Magneto Puller - Motion Pro
I can confirm that the RT2 uses the M27x1.0 LH puller as MarkT mentioned earlier.
12 Jul 2022 06:29
