Fender bracket measurement needed
- Dennis D
Fender bracket measurement needed was created by Dennis D
I need the distance between the mounting holes on the rear bracket on a 73 CT3 front fender.
I just obtained a fender and brackets and it looks a tad high off the tire to me. I have looked on
the net, but it is hard to tell from the pictures I have found. Thanks, Dennis
23 Jun 2022 18:48
Replied by Gr8uncleal on topic Fender bracket measurement needed
What size is your front wheel?
24 Jun 2022 00:07
- mike8162
Replied by mike8162 on topic Fender bracket measurement needed
Hey Dennis, it looks just like mine did before disassembly. I think the larger space between the fender and tire is because the CT3 has an 18" front wheel. I used a tape measure on mine and found that the rear bracket is 4" on center of the bolt holes from the fork to the top of the fender and roughly 11" from the rear to the center of the hole that mounts to the fork. The front brackets are 5 7/8" on center measured in a straight line.
Cheers
Cheers
24 Jun 2022 04:36
- Dennis D
Replied by Dennis D on topic Fender bracket measurement needed
Could you get me the centers on the holes that mount to the fender and the fork tube? I have a DT3 that I can compare measurements too to see if it is different. Thanks, D
When I measure between the mounting holes on this I get 3 7/8.
- Dennis D
3:50x18 Yokohama
24 Jun 2022 06:17
- mike8162
24 Jun 2022 10:29
- Pete-RT1
Replied by Pete-RT1 on topic Fender bracket measurement needed
Looks correct to me.
Yamaha CT1 007
Yamaha CT1-B The Doppelgänger
24 Jun 2022 13:07
- Dennis D
Agree, looks a lot like mine from the same angle.
24 Jun 2022 14:22
- Dennis D
Thanks Mike, same as mine. Now I'll have to find something else to fret over, LOL!
24 Jun 2022 14:27
