Is it possible to remove the oil tank sight glass without damaging it?
- Bartman512
Is it possible to remove the oil tank sight glass without damaging it? was created by Bartman512
I ordered a ebay oil tank for my DT2 but of course it's not for a DT2, as it has a banjo fitting and the sight glass is rear ward facing. It does have a brand new sight glass installed and I need it for my CT3. Any way to get that out to reuse?
07 Feb 2022 15:42
- Jim D
Replied by Jim D on topic Is it possible to remove the oil tank sight glass without damaging it?
Try pressurizing the tank with air? Don't know if it would work or not, but it's all I can think of that might work.
Tape plenty of rags around the glass to safely catch it if it does come out.... and always keep in mind that pressurized steel vessels can explode if over-pressured.
Fwiw, these folks will sell you a new sight glass at a reasonable price.
sumorubber.com/
sumorubber.com/
07 Feb 2022 16:48
- adguy2112
Replied by adguy2112 on topic Is it possible to remove the oil tank sight glass without damaging it?
The DT1 has a banjo and seems to fit your description. Why not send it back and buy a new sight glass?
07 Feb 2022 17:29
- Terry4624
Replied by Terry4624 on topic Is it possible to remove the oil tank sight glass without damaging it?
Hi. I've just joined as I'm restoring a '76 DT175 for a friend. We didn't know this site existed, just stumbled across it on Google. I removed the sight glass by warming slightly with my old hair dryer (workshop use) then pushed from outside with a long socket that fits just inside the rubber. Fell in the tank but retrieved pretty easily.
The problem now is: how to push in a new one? I'm hoping someone on here will be able to help with this?
The following user(s) Liked this Post: DT175DOUG
08 Feb 2022 11:42
- Schu
Replied by Schu on topic Is it possible to remove the oil tank sight glass without damaging it?
Installing my new one was very easy after putting a light film of oil on the outer surface. Didn't take much force at all. Popped right in there.
08 Feb 2022 14:07
Replied by RT325 on topic Is it possible to remove the oil tank sight glass without damaging it?
So you need to remove the new one & fit in another tank?. Can you heat it to soften the plastic/rubber stuff & flick it out--carefully of course. Then reheat if neccessary to fit it in. Not sure if it needs sealer but i'd think they're designed to be tight without. But then again, in & out & back in--sealer.
09 Feb 2022 18:07
- Bartman512
Replied by Bartman512 on topic Is it possible to remove the oil tank sight glass without damaging it?
Yep, heated it up with heat gun and popped right out and into new freshly painted oil tank
The following user(s) Liked this Post: RT325, adguy2112
10 Feb 2022 06:27
