Ct3 battery hook-up - Too many red wires.
  • goatboy56
  • goatboy56's Avatar Topic Author
Hello:
 Working on a ct3 that I just received and going through the wiring and this is how it came with the battery ( B ) not going to the rectifier (A) so I am thinking these need to be switched and also wiring diagram show fuse going in between battery and rectifier but it has male ends (rectifier also has a male end) so is it ok where it is.
Also I know you all like photos so here is one before I stared on the wiring.
Thanks,
John
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
The following user(s) Liked this Post: Quartermaster35
Last edit: 04 Feb 2022 07:14 by MarkT.
03 Feb 2022 10:08 #1
Replied by adguy2112 on topic Ct3 battery hook-up - Too many red wires.
I'll look at mine when I get home. Frankly, I think this is correct. I just replaced the battery in my CT3 and recall rectifier (red) had two wires going into a female lead with a single (red) male from the rectifier going in. The battery (red) went into the loom with a single female coming off the battery into a single male.
03 Feb 2022 13:52 #2
  • goatboy56
Replied by goatboy56 on topic Ct3 battery hook-up - Too many red wires.
Thanks and I would really appreciate if when you have a chance you could check it out.
 Also do not know where that emoji came from as it was suppose to be "(B)".
Thanks Again,
John
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
04 Feb 2022 05:56 #3
Replied by MarkT on topic Ct3 battery hook-up - Too many red wires.
I put some spaces around your "B" as you inadvertently used the short-hand text for the emoji...  B ) without the space is the smiley sunglasses guy.
04 Feb 2022 07:17 #4
Replied by Gr8uncleal on topic Ct3 battery hook-up - Too many red wires.
"I'll look at mine when I get home. Frankly, I think this is correct. I just replaced the battery in my CT3 and recall rectifier (red) had two wires going into a female lead with a single (red) male from the rectifier going in. The battery (red) went into the loom with a single female coming off the battery into a single male."
This is how my 1971 CT1 is also wired, so a good chance that yours is correct #goatboy56.
The following user(s) Liked this Post: MarkT, adguy2112
04 Feb 2022 07:45 #5
Replied by Pete-RT1 on topic Ct3 battery hook-up - Too many red wires.
Goatboy, your wiring is correct
Yamaha CT3 (in bits)
04 Feb 2022 09:52 #6
  • goatboy56
Thank you!
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
04 Feb 2022 12:56 #7
