Ct3 battery
- Bartman512
Ct3 battery was created by Bartman512
Finally got this box of barn find CT3 together and fired up now and I need to find a battery that will fit in this tiny origional battery box. Any rec's? Real curious to see if the headlight works as the old harness is pretty crusty, but it does have the old left handlebar switch which are hard to find it seems.
24 Dec 2021 07:02
Replied by Gr8uncleal on topic Ct3 battery
Here's a link to what some of us in the UK have used.
Parts list will give details of original wet battery if you want to go that way and these are still available.
CT1 Compatible Sealed Battery? - Vintage Enduro Discussions (yamaha-enduros.com)
24 Dec 2021 07:35
- Pete-RT1
Replied by Pete-RT1 on topic Ct3 battery
Different battery on the CT3, the CT1 battery won't fit.
You need this one www.yuasa.co.uk/6n4a-4d.html
Yamaha CT3 (in bits)
24 Dec 2021 15:05
- Quartermaster35
Replied by Quartermaster35 on topic Ct3 battery
I put one of these in my CT3.....obviously not original, but its a sealed unit and provides better performance than the original style OEM batteries.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1980 Yamaha 175 Tri-Moto
1969 Yamaha DT1 250
1981 Yamaha XS650 Special
1982 Suzuki GS550ES
1982 Honda 250R
1984 Honda Nighthawk "S"
2005 Kawasaki KLR650
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
24 Dec 2021 18:02
- gvthnks
Replied by gvthnks on topic Ct3 battery
I use a 12v version in my Honda XR250. Never had an issue with them taking or holding a charge and they're about 15 bucks when I need to replace them.
28 Dec 2021 13:18
- adguy2112
Replied by adguy2112 on topic Ct3 battery
QM how did you modify the battery box to accommodate the wider battery? I was thinking the tabs on the rear fender side of the box would need to be bent out then some sort of extension added. Definitely want to ditch the acid type.
- Quartermaster35
That is exactly what I did....... bent the rear tab back, which allows it to sit down the in the box ...... its sits in the box on an angle but it doesn't move around.
1973 Yamaha CT3 175
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
Prior Bikes:
1973 Suzuki TS90
1977 Yamaha IT175
1978 Suzuki 390SP
1969 Yamaha DT1 250
1982 Suzuki GS550ES
1982 Honda 250R
29 Dec 2021 18:09
- adguy2112
Perfect. Just ordered one. Thank you.
30 Dec 2021 05:09
Replied by MarkT on topic Ct3 battery
Remember to make sure terminals can't short out on seat pan.
The following user(s) Liked this Post: t-bone
30 Dec 2021 05:43
