Removing intake manifold studs from cylinder
- thumperstew
Removing intake manifold studs from cylinder was created by thumperstew
I've made an aluminum intake manifold adapter plate for my 70 DT1C. It will allow putting a spigot mount Mikuni VM/TM 32-34 carb on the bike. Do the intake manifold studs thread into the cylinder or are the pressed in? I need to replace them with M8 x 50mm flat head screws. Planned technique-double(or triple) nut the stud then heat/penetrantat the cylinder. Anyone else done this? This is a good, 1st OS cylinder, don't want to make more work. Thanks
24 Apr 2026 07:11
Replied by MarkT on topic Removing intake manifold studs from cylinder
Threaded, and Mikuni makes a flange adapter to convert to spigot carb. Just need to know the stud spacing to get the right one.
24 Apr 2026 08:32
- thumperstew
Replied by thumperstew on topic Removing intake manifold studs from cylinder
Thanks Mark. I have found/purchased manifolds with 60mm bolt spacing but the mount holes are for M6 allen head screws. When bored out for M8, there is no room for a nut/washer. Have considered SR500 exhaust nuts or custom M8 SHCS with smaller OD heads. What vendor do you suggest. Several vendors on ebay offer 60mm carb holders for the VM32-34 so figuring same part from everybody. Mikuni flange, M-VM34-200K, appears to have the correct mount bolt spacing and 8.5mm hole size, ordering one today. We'll see.
24 Apr 2026 09:51
I remove the studs and use allen head or torx bolts to attach rubber manifold adapter to cylinder. The 200K part number sounds like the correct one. It's been awhile since I got one but I think I have one around here someplace.
24 Apr 2026 10:10
