CT1 piston pin length
  • adguy2112
CT1 piston pin length was created by adguy2112
Hi all, just received partzilla delivery on a 71 CT1 Top end, the replacement piston pin is 10mm shorter than what came out of the bike, i now see an alternate pin number is listed as well 251-11633-00-00 with the shorter pin #137-11633-10-00. anyone come across this and what wax the preferred resolution? figuring the other part number is likely a longer version,
23 Sep 2024 23:00 #1
Replied by Swoop56 on topic CT1 piston pin length
The # 251 pin is the correct one for a 175 . The # 137 pin will be for a 125 .
The following user(s) Liked this Post: MarkT, Ht1kid, adguy2112
23 Sep 2024 23:16 #2
Replied by pabdt on topic CT1 piston pin length
if you take the part number in question and put it in partzilla search, you can then check bikes this part will work on. use the "fitment" option.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
24 Sep 2024 20:36 #3
Replied by landyr67g on topic CT1 piston pin length
hmmm...glad there are other dummies out there because this just happened to me a few months ago! Not sure how it happened....maybe I was shopping using my pdf parts manual and read wrong number from the AT page instead of the CT page.
Anyway, I discovered the mistake (after having my rebuilt crank and new piston assy balanced)...right when installing the piston onto the rod with the engine back in the frame. Thought about it a couple days and decided I could never forget if
I kept with the wrong pin. So tore down the engine and paid a bunch more to get everything re-balanced with correct pin. An expensive set back but its all back together now.
Regards,
Joe M
24 Sep 2024 22:23 #4
