1971 AT1 - Dies When Hot
Replied by MarkT on topic 1971 AT1 - Dies When Hot
Still available here too from some dealers and from Honda.  That said, as stock runs low, suppliers like Partzilla and others will often substitute the "BR" variant.
In a related note, NGK has discontinued production of the 5k ohm OEM plug caps. Purists might want to stock up...  or if you need a cap might be to time to go non-resistor cap and switch to the resistor plug?
05 Sep 2024 09:05 #11
Replied by RT325 on topic 1971 AT1 - Dies When Hot
Certain style of plugs have a fixed top so only way is to change the cap for one that fits. Not sure about plug you bought though.
05 Sep 2024 13:51 #12
  • Leeanderson38
  • Leeanderson38's Avatar Topic Author
Replied by Leeanderson38 on topic 1971 AT1 - Dies When Hot
Ok, so I took a closer look at the B8ES plug I purchased from amazon. The amazon item listed it as a B8ES but the actual markings on it say BP8ES and the S looks kind of funny. Maybe a counterfeit? Or does this look right? Also, you guys were correct and I was able to unscrew the top portion of the cap and now it fits into my plug wire no problem.
imgur.com/XtmVGQA
Either way, I decided to swap it out to see if it has any noticeable result. Haven't had a chance to get out and ride at all, so I'll have to wait and update you guys in a couple weeks after I get a chance to try it out.
Here is a vid of it running (relatively cold, not fully warmed up but enough to turn off choke) on the new plug:
imgur.com/JAY0bfA
17 Sep 2024 18:09 #13
Sounds good. Plugs get a lot of blame when the issue is elsewhere--just saying.
17 Sep 2024 18:18 #14
Replied by Wartruk43 on topic 1971 AT1 - Dies When Hot
Ring gap?
20 Sep 2024 13:58 #15
