Battery leaks
- nivlagusa
Replied by nivlagusa on topic Battery leaks
Ive got the tube routed in front of the battery box and going straight down in between the gap of the swing arm. There was a little spot of white on one of the plates on the chain. I think while sitting on its kickstand it flowed out of the battery box and dripped in between the oil tank and the box. The majority of the spill went on the floor. I rinsed the bike and then rinsed again with a bucket of warm water and baking soda. I didnt see any evidence on the fender or the swingarm so I got lucky in that regard. Couldnt have been but a few ounces of acid as the one chamber is low but not even below the fill line. Made a mess on the concrete for sure.
Regarding getting a replacement.. I dont think I want this style of battery again. I like the thought of the gelcel style battery. Any info on getting one of those that will fit in my 1971 battery box would be greatly appreciated. Thanks again. Pat
02 Sep 2023 10:07
#11
- 1971DT250
Replied by 1971DT250 on topic Battery leaks
The MotoBatt MBT6N4 won't fit in a '71 battery box. Need to install a battery box from a '72/'73. They pop up on eBay.
02 Sep 2023 15:25
#12
- nivlagusa
Thanks, Ill watch for one on ebay. Pat
04 Sep 2023 11:24
#13
- asco
Replied by asco on topic Battery leaks
This is a rare situation. Replace the defective part as if it were any other defective part.
a
a
YAMA-LAND RESTORATION,
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
( 818 ) 521-2109
1971 CT1-C (BRANDY)
1970 DT1-C (MONICA)
1972 AT2M (ZIFFLE)
1970 CT1-B (HULK)
1971 DT1E (GINA)
1970 CT1-B (CLIDE)
05 Sep 2023 07:50
#14
- Yamdog
Replied by Yamdog on topic Battery leaks
I had the same problem with the same battery.
The following user(s) Liked this Post: nivlagusa
21 Nov 2024 12:37
#15
- nivlagusa
Thanks for letting me know that. I was worried that maybe my DT1E was overcharging or some other phantom problem. I put another new battery similar to that one in this spring and it has worked just fine! Pat
12 Dec 2024 16:33
#16
- automan
Replied by automan on topic Battery leaks
Smells like an Exide battery.
The very worst.
cliff
The very worst.
cliff
16 Dec 2024 09:41
#17
