1969 - 1971 AT1 & CT1 Fuel Tanks Same Size?
  • Phils2888
  • Phils2888's Avatar Topic Author
I am curious if 1969 through 1971 AT1 and CT1 fuel tanks are the same physical size and interchangeable?
Thanks.
Phil
17 Sep 2021 04:35 #1
Replied by Gr8uncleal on topic 1969 - 1971 AT1 & CT1 Fuel Tanks Same Size?
Check on CMSNL or Partzilla for the model and years that you want to compare.
I have looked at both models for 1969 and the part numbers for the tanks for both start 248-24110 - this would indicate that, physically, they should fit either bike.
Don't use the facility available on both websites to see which models shared a part, as the full part number will also include a colour code for a specific years' model.
17 Sep 2021 04:43 #2
I've always thought they're the same--always looked same to me like a smaller DT1 tank. CT2 & AT2 changed shape, & filler cap.
17 Sep 2021 05:07 #3
Same gas tank except for paint color.
Other parts like headlight bucket and front fender are not...  at least on 69-71 12v US 125 models compared .to 69-71 US 175 models.
17 Sep 2021 05:36 #4
  • Phils2888
Replied by Phils2888 on topic 1969 - 1971 AT1 & CT1 Fuel Tanks Same Size?
Thank you Mark!
17 Sep 2021 17:25 #5
  • Phils2888
Thank you Rt325!
17 Sep 2021 17:26 #6
  • Phils2888
Thanks for the info! I was not aware of that info regarding the part numbers. Sure makes it easier!
Phil
18 Sep 2021 11:37 #7
Replied by Bobkoch73 on topic 1969 - 1971 AT1 & CT1 Fuel Tanks Same Size?
I have both here and the Measurements are close but not the same. 69 DT1 2" wide where it slips over the frame front 1" down. The CT1 is 2 3/4" at the same spot. DT1 9 Ltr. CT1 7 Ltr.
19 Apr 2026 17:16 #8
"I have both here and the Measurements are close but not the same. 69 DT1 2" wide where it slips over the frame front 1" down. The CT1 is 2 3/4" at the same spot. DT1 9 Ltr. CT1 7 Ltr."
I have concluded that Yamaha slightly changed the style of the AT1/CT1 tanks during 1970, but not the part number. I have two CT1B tanks (actually on UK fleabay at the moment), and they are slightly different from each other. I did check others on fleabay just to confirm my theory, and these differ in the same way.
20 Apr 2026 08:27 #9
Yes, CT1 tank is definitely different than a DT1 tank.
AT1 and CT1 tanks are the same except for paint color and the slight change Alan has mentioned.
20 Apr 2026 08:42 #10
