MX175A 1974 // information and specs?
- davidivjak
Replied by davidivjak on topic MX175A 1974 // information and specs?
Ha! Made it to twelve posts, so I guess I can show photos now?? I'll give it a try:
imgur.com/a/js3Yb6j
Here you can see some pictures right after the moment I bought this beauty up to the current status.
imgur.com/a/js3Yb6j
DT175MX '81 | R5F '72 | RD350LC '82
11 May 2026 00:23
#21
- davidivjak
I've pretty much finished the bike, just a few minor improvements before I can take it to the track and run it in.
There's one thing left that irritates me:
In the service manual you can see ignition timing marks on the flywheel as well as on the pickup. But I don't have the mark on the pickup. I didn't change the timing yet, just built in the stator and rotor and when I go to the desired timing which is 2.0mm BTDC, the mark on the flywheel aligns with the bended plate. Please look at the images to see what I mean:
imgur.com/a/g3Fz5kD
When flashing the ignition while running the engine, the mark on the flywheel does not align with the plate at idle. However it shifts somehow "digitally" when revving a little bit, but still not hitting the bended plate as a mark.
Can anyone explain how I should proceed to make sure my ignition timing is set correctly?
Thanks in advance!
Ahh btw, I bought an '76 YZ125 engine coming with an inner rotor ignition. I was checking if it would fit the MX, but saw one more red cable coming from the stator. The MX only has four cables: White/green, white/red, brown, black. The stator from the YZ has: White/green, white/red, black, brown, red.
So would I need the CDI from the YZ too to make it work?
imgur.com/a/g3Fz5kD
Thanks in advance!
Replied by MarkT on topic MX175A 1974 // information and specs?
How far are the marks off? A whisker or 2 inches? Firing early or late?
The early Hitachi CDI boxes don't age well. Most don't work anymore. Sometimes they start firing early or late quite a bit. There might be an aftermarket CDI box made that could fix it if that's what yours is doing.
While we're on the topic of CDI boxes, yes, you will need the YZ CDI box that matches the YZ ignition.
First step for timing is to absolutely make sure the marks are aligning at 2.0mm BTDC. (Or whatever you want timing to be). This needs to be a precision measurement.
The marks should align using a timing light with the engine revved up a little. If they are off a lot, something is probably wrong with the CDI pulsar or CDI Box. If the marks are off only a little, could the timing pointer be bent?
Yamaha manuals sometimes have mistakes. That might be a "combined" manual that covers all the MX models? They probably used a drawing for a 250 or something by mistake. Here's the correct picture for your CDI timing from an MX175-specific manual.
29 Jun 2026 07:57
#23
- davidivjak
Thanks Mark! That's good information. The flywheel perfectly aligns with the timing mark in the picture when piston is set to 2.0mm BTDC.
I remember when I flashed the ignition the mark on the flywheel moved a little when revving up, but I can't remember which direction. Will double check and correct the pulser according to what the flasher tells me to. Or do I definitely need a new CDI?
Replied by RT325 on topic MX175A 1974 // information and specs?
Was gonna be a short answer but got carried away.
It's bolted--nutted-- hard over to the right side, so i would shim it right side to get it close to central.
See what others "in the know" say because in my opinion anything on the left if floating unless 100% perfect.
"I think" the only way to get it perfect & the left shim loaded would be to fit the left bearing to the crank "with shim" so it pressed up to the shim.
Then bolt it to the right bearing "with shim" so its held over there.
Then heat the left case & sit together.
Of course all that depends on crank width being within spec when a new rod is fitted.
Sorry i'm over complicating it all, buy i'm not finished yet.
I have my own methods & depending on which way the wind is blowing.
I might assemble it up in the RH side then with left bearing in the case & shim on the crank then with the Yamaha tool pull/push the left case on so when screws in & tight i'd tap the left bearing to contact the shim hopefully not hard enough to affect the crank after going to great trouble to have it trued up from the rebuild.
www.partzilla.com/catalog/yamaha/motorcy.../mx175a/crank-piston
Sorry not sure what i was answering too.
i'll go back & see where i went wrong.
I don't know but its up there now. Ignore me lol.
Ok, looks like i was replying to post #20 sorry.
Ok, back on track & talking ignition.
Be interesting next time you strobe it because i found at work on a cdi yamy 100 farm bike that they spark twice a lap so near bdc ok 1.8 bbdc & tdc 1.8 before.
Maybe all do that where they're triggered by the magnets.
I wonder when they blow a seal out--like "really blow the right side out" & bend the retaining plate--if when flooded up it ignites what's in the case via the transfers.
Just pondering that's all.
08 Jul 2026 18:27
#27
- davidivjak
So I finally had time to check the ignition again. When flashing with the strobe again, the mark on the flywheel definitely did not align with the mark of the pulser, although both marks aligned when piston was set to 2.0mm BTDC. So while the engine was running and revving up a little, I made a mark on the engine case while strobing to determine the actual ignition timing. Then checked again with the clock and it was around 3.7mm BTDC...
I put the pulser as far to late timing as possible and flashed again. Now it seems like the ignition timing is at 2.0mm BTDC when revving up a little. I had to be really precise with the rpm btw, because when revving up too much the mark on flywheel totally disappeared. I don't have good feelings about this... does anybody know where I can get an aftermarket CDI? I don't really know where to start researching. I am also open for an entirely new ignition system like Ignitech or Vape, if somebody can recommend something that fits the MX?
Thanks in advance!
Thanks in advance!
18 Jul 2026 13:27
#28
- davidivjak
So I found this after a quick research.
This would be a replacement CDI unit, which is out of stock unfortunately:
rexs-speedshop.com/product/yamaha-cdi-36...0-360-yz125-250-360/
And I found two replacement ignition systems, this one even claims to fit the MX175A:
www.regulatorrectifier.com/collections/y...or-cdi-flywheel-coil
And I found this one as well, not 100% sure if it would also fit my engine:
www.vmxracing.com/yamaha-parts/yz250/197...100-125-hpi-ignition
Does anybody have experience with these ignition systems? Or can recommend anything similar?
Thanks!!
Thanks!!
19 Jul 2026 01:07
#29
Lots of options for complete system. For example any of the 1974-81 DT175 complete ignitions will fit engine, can't remember if MX175 had a smaller ignition side cover though, you should be able to use 74-76 DT175 ignition cover if needed for flywheel clearance.
Not sure of your intent with the bike? Internal rotor and small flywheel ignitions are not nearly as "forgiving" for normal riding.
The following user(s) Liked this Post: davidivjak
19 Jul 2026 13:28
#30
