wanted DT360 carb part
- jsmith6752
Replied by jsmith6752 on topic wanted DT360 carb part
my vin is 446-01-5137 made in December of 1973 the bike is title a 1974 DT360 the piece in question is #5 in partzilla list thanks can't find the info on the o ring
04 Nov 2024 19:50
#11
Replied by RT325 on topic wanted DT360 carb part
www.nichecycle.com/catalogsearch/result/?q=jet+setter+o+ring
This should/could be it. Check with Mark to be sure. Think they're all the same??
04 Nov 2024 21:56
#12
- goatboy56
Replied by goatboy56 on topic wanted DT360 carb part
O-ring is a 007 size. I was getting them at O'reilly's but have bought an o-ring set from Harbor Freight.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
05 Nov 2024 05:19
#13
- jsmith6752
size 7 thank you
05 Nov 2024 10:30
#14
- jsmith6752
I inspected the carb and found no numbers at all it's a stock Yamaha DT360 and I am looking for info on the needle jet setter piece that takes a O ring
05 Nov 2024 12:46
#15
Replied by MarkT on topic wanted DT360 carb part
Carb number should be stamped on front of carb across the flat surface where the "choke" (cold start circuit plunger) is located. Small stamping.
05 Nov 2024 13:00
#16
Replied by Gr8uncleal on topic wanted DT360 carb part
"I inspected the carb and found no numbers at all it's a stock Yamaha DT360 and I am looking for info on the needle jet setter piece that takes a O ring"
There will be numbers on the carb, but probably covered in dirt. I'd expect to see 445, followed by two other characters, stamped on yours.
- jsmith6752
Thanks to the good people on this website I was able to locate the carb part I was looking for. Thanks to the good people on this website I was able to locate the carb part I was looking for. For some reason I could not add a photo.
- pahiker
Replied by pahiker on topic wanted DT360 carb part
You need to use a 3rd party hosting site like imgur for pictures. Glad you're all set!
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
2024 Suzuki DR650
08 Nov 2024 16:48
#19
