1974 GT80 headlight, ring
  • principal282
  • principal282's Avatar Topic Author
1974 GT80 headlight, ring was created by principal282
Yamaha part nmrs
lens assembly
338-84120-60-00
6V, 25/35 w
about 5 inches across, not the normal 5.75
Headlight rim
261-84315-61-00
17 Jul 2023 20:15 #1
Replied by MarkT on topic 1974 GT80 headlight, ring
I forgot to look for the parts I think I have. I will look tomorrow.
17 Jul 2023 20:29 #2
  • principal282
Replied by principal282 on topic 1974 GT80 headlight, ring
Thanks!!  We are marching on, everything is stripped and the cylinder is going to the machine shop tomorrow! :)
17 Jul 2023 20:31 #3
I have several of the 5" rings and buckets from the AT series...  bucket has the square mounting holes for the rubber mounts and a high beam pilot light hole...  I don't know if the little 80's had those.  Chrome ring is the same part number though.
I found two 5" headlights with the "bayonet" bulb mount...  one is old and used...  the other is NOS.  I don't know if I have the bulb or the pigtail...  I have to look...  too hot right now in the shed with lows near 90 and highs over 110.
18 Jul 2023 12:45 #4
  • principal282
Thanks for checking!!
so the each component is kind of separate, glass, ring, housing?  Interesting.  Guy could probably find a 6v bulb easier than a whole sealed beam setup
18 Jul 2023 18:21 #5
Yes the sealed beam or this type lens/reflector with replaceable bulb has two little bolts and nuts that hold it into the rim. There is also a spring and adjuster screw setup... not sure if I have that hardware.
Your original rim and lens/reflector should be the same system?
I might have a bulb. I will look.
The following user(s) Liked this Post: Ht1kid, principal282
18 Jul 2023 20:22 #6
