1973 Rt-3
- Hammer
1973 Rt-3 was created by Hammer
Folks, It's time. I have decided that the time to let someone else enjoy what has, for me, been nothing but GREAT times for me. I bought this, original, unrestored, on-line. When it got here, I dealt with the usual problems, like the clutch actuator (with a permanent fix!) and then added everything I would have added back in 1973, if I only had the money. It's been to a number of California Dreamin' get togethers last one being in 2019, where I was T-boned outside of Lancaster, enroute to Hungry Valley. Everything damaged was replaced, with BETTER parts than I had! Since then I haven't ridden it very often, as my right knee is bad (I was supposed to have knee replacement, but our local Kaiser Permanente hospital discovered they had contaminated water, so I' m now in limbo. I haven't ridden it for over a year (float bowl was drained and is dry). I went out to go riding, and decided to replace the plug, as it had been in for over 18 months. Pulling off the plug cap, I pulled the cap off of the lead itself. I shortened it by 1/4" and found that it now didn't reach, so moved it into the other plug hole. It's no-spark, probably since I haven't cleaned the points for over a year, and it had been setting. At least the float bowl was drained, and is dry. Anyway, I have two spare coils if it's that as well. Starting up front, I replaced the fork springs with S&W springs, the seals, and new fork oil. There is a 12V voltage regulator, and I'm running an H-4 Halogen light (brite!) and haven't blown a bulb since 2014. It's got a Barnett clutch and springs, which were needed after adding and jetting for a Sleeper Pipe from Dave Meis (#24?), and the head has had .005" milled off. It's got a K&N air cleaner, and a smaller tail/brake light that won't bite you in your privates. It has a spring-loaded chain tensioner, originally designed for the DT-2/3 MX bikes, and a new chain. It's also running a 16-tooth countershaft sprocket. It handled rides from my home to the Border where I worked (INS/ICE/CBP), a 48 mile round trip, all freeway with no problem. It's on a first over piston and rings, and I have the next oversize piston & rings from Wiseco ready when needed. The autolube is working great as well. I have enough spare parts, lights, gaskets, seals, levers, etc. to keep it running for another 15 years, or longer. I can't add photos, but it's in my thumbnail, and anybody that has been to Cal Dreamin' and has ridden it, can speak to it's performance. I have it jetted for approx 400 feet above sea level, and drop to a 270 when at Johnson Valley/Hungry Valley. Lot's of spare jets, too. There's also an item about my rebuilding it, after it was sabotaged--it's on here, somewhere...
Anyway, if interested, text me at 619/300-2049; I'm in the San Diego area. A rear end carrier with loading ramp, large square mount, comes with it, too, if wanted.
