Wanted: 76 DT400 wiring harness
- TheBeardedOne
Wanted: 76 DT400 wiring harness was created by TheBeardedOne
I'm looking to put lights on my 76 DT400. The previous owner stripped it for ice racing, so I need a few parts:
Wiring harness
Handlebar switches
Regulator
Rectifier
Brake switches
Ignition switch with key
And maybe a set of gauges with the bracket and cables if I'm lucky
I think the only thing I can't buy new is the harness though, so that's what I really need at the moment. I could probably cobble one together, but I prefer having the factory connectors where possible.
Wiring harness
Handlebar switches
Regulator
Rectifier
Brake switches
09 Apr 2023 19:15
Replied by MarkT on topic Wanted: 76 DT400 wiring harness
DEET makes harnesses for most models.
09 Apr 2023 20:39
- TheBeardedOne
Replied by TheBeardedOne on topic Wanted: 76 DT400 wiring harness
Thank you Mark! I just sent DEET a message.
09 Apr 2023 21:01
- TheBeardedOne
It appears DEET doesn't have any at the moment. I may be able to make a '75 harness work instead (as long as the stator plug is the same) since I'm replacing almost all of the other electronics anyway.
10 Apr 2023 05:16
- Lizeec
Replied by Lizeec on topic Wanted: 76 DT400 wiring harness
One thing to note is that the 1976 DT400C came factory wired with a voltage regulator mounted on the air filter box, the 1975 DT400B did not, I’m unaware of any other differences the main harness may or may not have.
10 Apr 2023 18:05
- nhsteve
Replied by nhsteve on topic Wanted: 76 DT400 wiring harness
I put a repro harness for a '75 DT250 on a bike a few years back, came from England.
I spotted a NOS one in Australia on eBay this AM and a decent looking used one. System would not allow me to copy the links for you.
28 Apr 2023 06:18
Ebay started blocking linking from other websites.
You can use the "insert link" function as long as you don't use the ebay link in the display text box
The following user(s) Liked this Post: nhsteve, Ht1kid
