GFrench - EnduroRide Special
Replied by mdscott on topic GFrench - EnduroRide Special
When I was heating the brg race I was checking with a laser temp gauge, It was about 220 deg.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
25 Nov 2017 13:08 #181
Replied by yamahahaha on topic GFrench - EnduroRide Special
Gee Mr French , I wish I had your skills and knowledge
www.gstatic.com/tv/thumb/tvbanners/184052/p184052_b_v7_ab.jpg
The following user(s) Liked this Post: GFrench
25 Nov 2017 14:02 #182
  • GFrench
  • GFrench's Avatar Topic Author
  • Supporting Moderator
Replied by GFrench on topic GFrench - EnduroRide Special
Finally got a chance to spend some time in the garage to make more progress on the Black WIdow.
First step today was to finally get all of the Bearings installed in the cases- Bearings have been in the Freezer for 3 days now so they are ready to go!
First step is to place the case halves into the over and set the temp for 250 degrees- 15 min and the bearing dropped in place like no ones business!
Always good to have the Aluminum Driver set ready to go just in case you need to tap anything in-
Now just let the cases cool down and we got a perfect start to a complete Engine Rebuild.... Bike is going to fly ultra smooth now!
1971 DT1F MX 250
1973 RT3 360 "Black Widow"
1973 RT3 360
1976 IT 400 / redesigned as a 75 MX400
Last edit: 10 Dec 2017 10:29 by GFrench.
10 Dec 2017 10:26 #183
  • GFrench
As I posted earlier... It has been confirmed by the Bill Bune Boys that the Stator side Crank Shaft was bad when they got a closer look at it.
If I would have not decided to split the cases and pull everything apart may have never realized the Main Bearing on that side was freely spinning on the shaft causing some tremendous heat transfer for sure!!
So found a decent one on EBay and will be shipping it to them tomorrow and they will use the best parts from both Cranks and sending me a beautiful like new reassembled Crank!
Also got my Cylinder and Piston back from Enduronut- Thank you for the outstanding customer service!
Having Dave look things over he determined just a real like honing to clean things up a tad is all that is needed for now. Just amazing the punishment these old RT1's can take!
Fresh new Bearings in the Rear and Front Wheel installed- Smooth as silk now!
1971 DT1F MX 250
1973 RT3 360
10 Dec 2017 10:47 #184
  • GFrench
1971 DT1F MX 250
1973 RT3 360
10 Dec 2017 10:56 #185
  • GFrench
Decided since I have gone this far... time to address a few Rock chips and a couple of dings in on the Oil Tank and Headlight.
Ready now to apply a light Black Base Coat and then 3 coats of SprayMax 2K clear- Stuff is amazing and easy to use!
1971 DT1F MX 250
1973 RT3 360
Last edit: 10 Dec 2017 11:02 by GFrench.
10 Dec 2017 11:01 #186
Replied by 2fishkev on topic GFrench - EnduroRide Special
Just want to thank you for all your threads detailing your builds! There’s always plenty to learn and some to, ummm, copy.... hope ya don’t mind. Once again, nice work!
13 Dec 2017 15:29 #187
  • GFrench
Thank you- always fun to share information that might help someone else. Glad you find the info useful.
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: MACE6772
13 Dec 2017 15:57 #188
  • GFrench
Got a call from Bill Bune's place yesterday and my Crank is now done! Packed up and on the way back to me.
Will post up some Pic's of the new/freshed up crank as soon as it arrives.
Good news was the donor Crank I got of Ebay was A OK and now have perfect Specs on the Stator side Shaft... no more bearing spinning freely!
Got the first coat of primer on the Oil Tank and Headlight Bucket that were showing some signs of well ridden miles- a couple of rock dings.
Will Scotch Brite pad everything smooth and then apply one nice coat of Krylon Gloss black... then a final working of the Scotch brite pad to remove the gloss finish and then will be time to apply the Clear Coat.
SprayMax 2k Clear Coat has arrived with a nice Spray attachment- Stuff makes me look like a pro!
1971 DT1F MX 250
1973 RT3 360
Last edit: 16 Dec 2017 07:48 by GFrench.
16 Dec 2017 07:43 #189
  • GFrench
Finally got some time to unpack the freshly rebuilt crank!
What an amazing job they did- Wow- this engine is going to run so smooth!
Now ready for next step is to pull the crank thru the primary side/bearing first.
The donor crank provided a perfect to spec Startor side shaft... new beaing will lock on as it is suppose to now!
Also a practice run dropping the transmission in to bench shift/test it... glides thru all the gears perfectly!
1971 DT1F MX 250
1973 RT3 360
The following user(s) Liked this Post: Makotosun, FrankC, Pillsbury
Last edit: 26 Dec 2017 13:00 by GFrench.
26 Dec 2017 11:53 #190
